How Does Pickup Position Affect Sound? | Guitar Kit World Skip to content
Types of pickups
Pickup positions
The neck position
The middle position
The bridge position
Playability
Unboxing a Blank Guitar Kit
Previous article How do you fix the guitar binding?
Next article How to check the neck alignment and neck angle
