How do you paint a solid body guitar?
There’s nothing quite like the sound of a solid body electric guitar. The tone is warm and rich, yet still cuts through when you need it to. What’s even better is that you can paint them to create a unique look that reflects your own personality or even just to make your guitar stand out in a sea of branded guitars. Here’s how to paint a solid body guitar.
To learn more about getting rid of excess glue in your DIY guitar, check out this article: How to Remove Excess Glue from a Guitar Kit
Take The Quiz
The World’s Most Expensive Guitars and How Your DIY Kit Tops Them All
When collectors talk millions of dollars, they’re usually referring to historic guitars owned by ...
Neck Profiles for Large & Small Hands: U-shaped, V-shaped, C-shaped, Flat C-shaped
A closer look at U-shaped, V-shaped, C-shaped, Flat C-shaped Neck Profiles. While variety is most...
Scott’s First DIY Guitar Build
Building a guitar is more than just assembling wood and hardware. It’s a chance to create somethi...
Compare products
Select first item to compare
Select second item to compare
Select third item to compare
Compare
