There’s an endless list of choices available when it comes to guitar finishing. Options include oiling, staining, finishing in a graduated combination of colors e.g. sunburst to a standard solid color finish. To make matters even more complex, within these available options there are also any number of material considerations and methods of application to consider.
Guitar Finish Types
Recommended: DIY Guitar Finishes: How to Choose the Right Finish for Your Guitar Kit
Recommended: Guitar Tonewoods: How they affect Tone and Playability
Take The DIY Guitar Quiz
Guitar Finishing Materials
Ventilation mask
Sandpaper
Painters tape
Sealed Plastic Containers
Tinted Grain Filler
Stain
Clear Coat - Wax or Oil
Recommended: Luthier Tools for DIY Guitar Kits
Guitar Finishing Step-by-Step
Step 2: Final Sanding
Your next step should be to sand the guitar. Look for any scratch marks left from the factory and sand until these are removed. If the marks are deep and require a low grit sandpaper you will need to work your way up to at least a 450 grit sandpaper once the scratch is no longer visible as each grade of sandpaper will leave scratch marks that must be removed with each higher grade of sandpaper applied.
Finishing Tips for Veneered Kits
If your kit includes a veneer top (like flamed, spalted, or quilted maple), it’s important to take extra care during prep and finishing. Veneers are made from real wood and often have thin, delicate layers that are easy to damage if not handled carefully.
⚠️ Note: These veneers are natural wood, not synthetic or printed. It’s common to see minor imperfections or distressed sections—this is part of their character. Handle with care to preserve their beauty.
DO:
- Inspect the veneer under good lighting for glue spots, blemishes, or imperfections that may resist stain.
 - Sand very lightly by hand using 400 grit sandpaper. Just a few passes to smooth it—no pressure.
 - Use a clean sanding block or sponge (no power tools!) to avoid burning through the thin veneer.
 - Raise the grain by wiping gently with a damp cloth and then lightly sanding again with 400 grit.
 - Consider masking edges or fragile spots if they look thin or distressed.
DON’T:
- Don’t use coarse sandpaper (nothing under 400 grit).
 - Don’t use a power sander or press down while sanding—veneers are thin and easy to sand through.
 - Don’t overdo grain filling—most veneered tops don’t need it and some fillers can muddy the figure.
Best Finish Options For Kits With Veneer Tops
- Stain or Dye to highlight the wood grain figure (flame/quilt).
 - Translucent or clear coats like shellac or poly to preserve the pattern.
 - Oil finishes like Tru-Oil also work well if applied in thin layers and gently buffed.
To learn more about finishing types we recommend reading the following guide: DIY Guitar Finishes: How to Choose the Right Finish for Your Guitar Kit.
Step 3: Final Clean
Step 4: Masking
To ensure a flawless finish, take the time to tape off any areas of your guitar, such as the neck pocket, pickup holes and fretboard that don't need finishing.
Now that the guitar is ready to apply your finish it’s time to use either your tinted grain filler or dark stain to highlight the grain of the timber. You can read more about mixing grain filler here. It’s always best to test your mix on a spare piece of timber first if available and then simply apply the product and wait for it to dry.
Step 6: Re-Sanding
Step 7: Staining
- Follow the manufacturer’s recommendations for mixing.
 - If your guitar has a veneer maple top e.g. most LP-style Guitar kits come with a thin maple veneer you will need to be careful to only apply the stain very lightly. If you saturate the veneer it can start to bubble which will result in the veneer being required to be completely removed and requiring you to perform many of the steps listed above over again.
 - Always use a clean rag. While it may seem obvious that using a rag that has been used for other purposes previously is a bad idea e.g. I have known of a signwriter who mistook a clean rag for a previously used rag that had been exposed to paint thinners and caused a number of problems.
 - Your hand should be constantly moving to achieve an even finish. If you use inconsistent hand movements it is likely that your stain will look heavier in some section than others which should be avoided at all costs.
Step 8: Scraping the Binding
Step 10: Final Sanding
Step 11: Polishing
