Engineered Zebrawood DIY Guitar Kits
Engineered Zebrawood is made by compressing dyed cottonwood (a poplar sub-species) using heat, glue, and pressure to create its signature striped look. It’s denser than mahogany or basswood and has tonal qualities closer to real hardwood—making it a great choice for guitar builders.
If you're interested in learning more about how different tonewood affect the tone and playability we recommend you to read – Guitar Tonewoods: How they affect Tone and Playability.
Watch & Learn with ABD (Anthony Darrus)
Anthony Darrus brings the build process to life with his clear, hands-on video series. His tutorials are engaging and practical, offering plenty of tips along the way. If you’re just getting started or want inspiration, we highly recommend watching his build series.
Types of guitar finishes:
  1. Oils and waxes
  2. Shellac
  4. Polyurethane (‘Poly’)
  5. Polyester
    Safety Precautions
    As a longtime contributor at Guitar Kit World, Nathan has spent more than a decade helping guitar builders turn basic kits into stage-ready instruments...
    Related Products
    Compare products
    Select first item to compare
    Select second item to compare
    Select third item to compare
    Compare
