Guitar Pickups Explained
Recommended: Pickups for DIY Guitar Kits
- Contact Pickups (essentially microphones)
- Piezo Pickups (Which use crystals and don’t pick up outside interference as a result. They also sound fantastic)
- Active Pickups (Which require a source of electricity such as a battery)
Magnetic Pickups Explained
Single Coil Pickups
Recommended: Copper Shielding Your Guitar's Pickup Cavity
Humbuckers
Humbuckers as the name might suggest ‘buck’ this unwanted hum by creating two separate signals that essentially cancel each other out. Because they are less affected by unwanted frequencies by nature and use a much larger magnet they tend to be better suited to higher output. This is the reason you will see humbuckers used in metal and heavy rock.
What Does This Mean To You?
So essentially if you are looking for a thicker, higher output sound a humbucker will be a better fit for you. If however, you prefer a brighter, twangier tone a single coil will be best. If in doubt consider the guitar tones and styles of music you prefer e.g. Fender or Gibson and go with a similar style of guitar kit or even better grab yourself one of each.Where Does Tone Come From?
Need a wiring diagram for your build? Browse every kit and pickup combo in our community: Find your wiring diagram →
