Guitar pickups explained
Magnetic Pickups Explained
Single Coil
Single Coil Pickups
Humbuckers
Humbucker Style
Humbucker Style Pickup
What Does This Mean To You?
Where Does Tone Come From?
Unboxing a Blank Guitar Kit
