Left-Handed Mahogany body X-style Guitar Kit
SKU EXP-LMEG-1
Original price $319.99 USD
Current price $239.99 USD
$239.99 USD - $239.99 USD
Build Difficulty: 4/10
Understand this score
Build your own left-handed DIY guitar with a mahogany body and neck, ebony fretboard, and pearl white Trapezoid fretboard inlays kit.
  • Hand Orientation: Lefty
  • Neck Joint: Set-In
  • Neck Binding: Single Black
  • Body Type: Solid
  • Body Material*: Mahogany (1 pc)
  • Body Top Veneer*: None
  • Neck Material*: Mahogany (1 pc)
  • Headstock Shape: 6-in-line (design might differ)
  • Fretboard Material*: Ebony
  • Inlays: Trapezoid, Pearl White
  • Nut Material: Bone
  • Hardware Finish: Gold
  • Cavity Covers*: Black
  • Number of Frets*: 22
  • Scale*: 628mm / 24.75″
  • Electronics*: 1V, 1T, 3-Way Toggle
  • Pickups*: 2 Humbuckers
  • Bridge*: Tune-O-Matic w/ stopbar
  • Neck Shape*: C-shaped
  • String Material*: Steel
  • Machine Heads*: Closed
  • Truss Rod: Double Way
Left-Handed Mahogany body X-style Guitar Kit is in stock.
Compare products
Select first item to compare
Select second item to compare
Select third item to compare
Compare
