E35 Semi-Hollow Guitar Kit with Split Parallelogram Ebony Fretboard Inlays
SKU E335-RMEG-1
Original price $319.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
Build Difficulty: 8/10
Understand this score
Build your own semi-acoustic DIY guitar kit with Flamed Maple Veneer Mahogany body and Ebony Fretboard with beautiful Split Parallelogram Pearl White inlays.
  • Headstock Shape: Royal
  • Headstock Binding: Single Ivory
  • Neck Material: Mahogany
  • Neck Binding: Single Ivory
  • Neck Joint: Set-In
  • Fretboard Material: Ebony
  • Fretboard Inlays: Split Parallelogram, Pearl White
  • Body Material on Top, Back & Sides: Mahogany Plywood
  • Body Center Block Material: Mahogany
  • Body Top: Flamed Maple Veneer
  • Body Binding: Multi-Ply Ivory
  • Electronics: 2V, 2T, 3-Way
  • Pickups: HH
  • Hardware Set Finish: Gold
  • Bridge & Tailpiece: Tune-O-Matic w/ stopbar
  • Nut Material: Bone
  • String*: Steel
  • Machine Heads*: Closed
  • Truss Rod: Double Way
    E35 Semi-Hollow Guitar Kit with Split Parallelogram Ebony Fretboard Inlays is in stock.
    Compare products
    Select first item to compare
    Select second item to compare
    Select third item to compare
    Compare
