The Work Area
Getting Started
(View on Amazon)
Sanding Blocks
Not long ago, students in ART 4073 at Southern Arkansas University began shaping blocks of wood i...
Hey DIY guitar builders! Today we're tackling one of the most nerve-wracking parts of any guitar ...
