Sanding a Guitar Body Prior to Painting
Related: unfinished guitar kits, solid body guitar kits
The Work Area
Getting Started
Sanding Blocks
Ready to Start Your Build?
If you're sanding and prepping your first guitar kit, check out our beginner-friendly guitar kits — they come with step-by-step assembly manuals and everything you need. Or browse all in-stock DIY guitar kits to find the right project for your skill level.
Ready to build? Check out our explore all guitar kits.
