How to Wire a 1 P90, 1 Vol, 1 Tone Guitar
Whether you are a beginner or an experienced musician, there are so many reasons why learning how to wire a guitar will benefit you. In this video, you will learn how to wire a specific set up of pickups. We will demonstrate wiring a 1 P90, 1 Volume, 1 Tone Guitar.
If you’ve ever wondered how guitar pickups work or the differences between pickup types, this article will clear up the mystery: Pickups for DIY Guitar Kits
Take The Quiz
The World’s Most Expensive Guitars and How Your DIY Kit Tops Them All
When collectors talk millions of dollars, they’re usually referring to historic guitars owned by ...
Neck Profiles for Large & Small Hands: U-shaped, V-shaped, C-shaped, Flat C-shaped
A closer look at U-shaped, V-shaped, C-shaped, Flat C-shaped Neck Profiles. While variety is most...
Scott’s First DIY Guitar Build
Building a guitar is more than just assembling wood and hardware. It’s a chance to create somethi...
Compare products
Select first item to compare
Select second item to compare
Select third item to compare
Compare
