How to Install Pre-Wired Pickups
pre wired Pickups
Dimarzio Vintage Twang
$99.00
Only $99.00! limited stock
$119.9
Click here to save over $90
$229.00
Click here to save over $50
EMG GC21 SA Prewired
$199.00
$299.00
Tools needed
  • New pre-wired pickup
  • Diagonal Cutters
  • Half Inch Box-End Wrench
Getting Started
The Wiring
Removing the old Pickups
Adding the New Pickups
See More Guitar Kits >>>
Compare products
Select first item to compare
Select second item to compare
Select third item to compare
Compare
