How to Install Pre-Wired Pickups
$99.00
$119.9
$229.00
$199.00
$299.00
Tools needed
Installing a pre-wired pickup assembly only requires a few basic tools and some solder. These tools will allow you to take out the existing pickup assembly as well as installing the new one into your guitar. It's not all that tricky and the entire job can be finished quickly.- New pre-wired pickup
 - Diagonal Cutters
 - Half Inch Box-End Wrench
Getting Started
First, you’ll need to remove the strings from the guitar so they’re not in the way and don’t get damaged. You will also need to remove the screws that hold the pick-guard onto the guitar body if applicable. You should also remove the two screws that hold the output jack plate on.The Wiring
There are three wires that will need to be cut from your current setup. One is the ground wire that goes from the tremolo claw to the casing ground. Clip this wire as close as you can to the casing with your diagonal cutters. The second two wires you will need to clip are under the output jack plate, which is why you needed to remove the screws earlier.Removing the old Pickups
Adding the New Pickups
