$99.00
Only $99.00! limited stock
$119.9
Click here to save over $90
$229.00
Click here to save over $50
$199.00
$299.00
Tools needed
- New pre-wired pickup
- Diagonal Cutters
- Half Inch Box-End Wrench
Getting Started
The Wiring
Removing the old Pickups
Adding the New Pickups
See More Guitar Kits >>>
Hey DIY guitar builders! Today we're tackling one of the most nerve-wracking parts of any guitar ...
