💡 Recommended: Guitar Finishing Safety Tips To Follow
Courtesy of Mike M.
Step 1: Use a heat gun
Step 2: Apply heat
Apply heat evenly and consistently to the binding, moving the heat gun along the length of the binding. When fixing the binding of a guitar using a heat gun, it's important to keep the heat gun at a safe distance from the guitar to prevent damage. As a general rule, it's recommended to keep the heat gun about 6 inches to 8 inches away from the binding.
Step 3: Use a plastic scraper
Step 4: Let it sit
💡 Recommended: How to Perform a Complete Final Setup on Your Guitar
Summary:
💡 Recommended: Common Mistakes to Avoid When Building an Electric Guitar Kit
