Types of pickups
Pickup positions
The neck position
The middle position
The bridge position
Playability
Find Your Ideal Pickup Configuration
Want to hear the difference for yourself? Build a guitar with the pickup layout that suits your style. Browse our humbucker guitar kits, P90 pickup guitar kits, or explore the full range of DIY guitar kits to find the right setup for your sound.
