Pickup position is one of the most important factors that determines the sound of an electric guitar. The pickups on a guitar are responsible for converting the vibrations of the strings into an electrical signal that can then be amplified and heard through a speaker. The position of the pickups relative to the strings affects the way the pickups capture the vibrations of the strings, which in turn affects the tone and timbre of the guitar's sound. 💡 Recommended: How do guitar electronics work? Types of pickups There are two main types of pickups on electric guitars: single-coil pickups and humbucking pickups.
Pickup positions
The neck position
The middle position
The bridge position
Playability
Find Your Ideal Pickup Configuration
Want to hear the difference for yourself? Build a guitar with the pickup layout that suits your style. Browse our humbucker guitar kits, P90 pickup guitar kits, or explore the full range of DIY guitar kits to find the right setup for your sound.
Need a wiring diagram for your build? Browse every kit and pickup combo in our community: Find your wiring diagram →
