Guitar Finishing 101: The Highlighted Grain & Stain Finish | Guitar Kit World Skip to content
There’s an endless list of choices available when it comes to guitar finishing. Options include oiling, staining, finishing in a graduated combination of colors e.g. sunburst to a standard solid color finish. To make matters even more complex, within these available options there are also any number of material considerations and methods of application to consider.
Guitar Finish Types
Recommended: DIY Guitar Finishes: How to Choose the Right Finish for Your Guitar Kit
Basswood
Basswood
Paulownia
Paulownia
Alder
Alder
Ash
Ash
Mahogany
Mahogany
Flamed Maple
Flamed Maple
Quilted Maple
Quilted Maple
Spalted Maple
Spalted Maple
    Take The DIY Guitar Quiz
    Guitar Finishing Materials
    Ventilation mask
    ventilation mask for painting
    This should always be your first port of call if finishing a guitar, fumes have the potential to make you sick and in severe cases have caused brain damage. While you should wear it for both sanding and finishing, we recommend you purchase a ventilation mask suitable for painting. Remember finishing supply fumes are no joke, please read our article on guitar finishing safety before proceeding you are unaware of the potential risks.
    Sandpaper
    (View on Amazon)
    Painters tape
    Painters tape
    (View on Amazon)
    Sealed Plastic Containers
    sealed plastic containers
    Tinted Grain Filler
    (View on Amazon)
    Stain
    stain
    (View on Amazon)
    Clear Coat - Wax or Oil
    (View on Amazon)
    (View on Amazon)
    Recommended: Luthier Tools for DIY Guitar Kits
    Guitar Finishing Step-by-Step
    Step 2: Final Sanding
    Final sanding
    Your next step should be to sand the guitar. Look for any scratch marks left from the factory and sand until these are removed. If the marks are deep and require a low grit sandpaper you will need to work your way up to at least a 450 grit sandpaper once the scratch is no longer visible as each grade of sandpaper will leave scratch marks that must be removed with each higher grade of sandpaper applied. If your guitar has a maple veneer (as per the image above) it's important that you avoid sanding through the veneer as it is often quite thin.
    Step 3: Final Clean
    Step 4: Masking
    To ensure a flawless finish, take the time to tape off any areas of your guitar, such as the neck pocket, pickup holes and fretboard that don't need finishing.
    Ebony tinted grain filler
    (View on Amazon)
    Now that the guitar is ready to apply your finish it’s time to use either your tinted grain filler or dark stain to highlight the grain of the timber. You can read more about mixing grain filler here. It’s always best to test your mix on a spare piece of timber first if available and then simply apply the product and wait for it to dry.
    Step 6: Re-Sanding
    sanded - highlighted grain
    Step 7: Staining
    Stain Finish
    (View on Amazon)
    • Follow the manufacturer’s recommendations for mixing.
    • If your guitar has a veneer maple top e.g. most LP-style Guitar kits come with a thin maple veneer you will need to be careful to only apply the stain very lightly. If you saturate the veneer it can start to bubble which will result in the veneer being required to be completely removed and requiring you to perform many of the steps listed above over again.
    • Always use a clean rag. While it may seem obvious that using a rag that has been used for other purposes previously is a bad idea e.g. I have known of a signwriter who mistook a clean rag for a previously used rag that had been exposed to paint thinners and caused a number of problems.
    • Your hand should be constantly moving to achieve an even finish. If you use inconsistent hand movements it is likely that your stain will look heavier in some section than others which should be avoided at all costs.
    Stain ball cloth
    Step 8: Scraping the Binding
    Scraping the binding
    Highlighted grain and stain guitar finish
    Step 10: Final Sanding
    Step 11: Polishing
    As a longtime contributor at Guitar Kit World, Nathan has spent more than a decade helping guitar builders turn basic kits into stage-ready instruments...
    How to Finish A DIY Guitar Kit Neck and Fretboard
    In terms of playability, a guitar’s neck is the most important component of a guitar. It’s the pr...
    Previous article Pickups for DIY Guitar Kits
    Next article Guitar Kits That Don't Need Much Soldering
