Engineered Zebrawood Guitar Kits
Types of guitar finishes:
  1. Oils and waxes
  2. Shellac
  4. Polyurethane (‘Poly’)
  5. Polyester
    Safety Precautions
    Unboxing a Blank Guitar Kit
    Next article Copper Shielding Kit Guitars
