At Guitar Kit World, we have shipped over 5,000 kits to builders in more than 30 countries. Every kit on this list is one we have built ourselves, tested, and watched thousands of customers build. This is not a theoretical ranking — it is based on real build outcomes, support conversations, and feedback from our community.
How We Picked These Kits
We build guitars for a living, and we test every kit we sell. This list is based on three things: build quality of the components, how much you learn during the process, and the sound of the finished instrument. We also factored in feedback from over 10,000 builders who have completed our kits.
Rather Build It With an Instructor?
If you would rather learn the process properly before going it alone, independent luthiers run build your own guitar workshops where you shape, finish, wire, and set up a complete instrument over a few sessions. You take the finished guitar home.
Best Overall: ST-style Guitar Kit (Ash Body, Pau Ferro Fretboard)
If you can only build one guitar, make it this one. The ash body delivers bright, articulate tone with natural resonance. Three single-coil pickups with a 5-way selector give you classic clean tones through thick rhythm sounds. Bolt-on neck construction makes this the most forgiving kit to assemble. The pau ferro fretboard adds warmth without the maintenance concerns of other tonewoods.
What you will learn: 5-way pickup wiring, wood finishing on open-grain tonewood, neck pocket fitting, tremolo setup.
Best for: First-time builders, blues and rock players, anyone who wants a versatile workhorse guitar.
Two pickups, one output jack, and the simplest wiring in any electric guitar. That is why this is the kit we recommend for your first build. The basswood body is light and easy to sand. The maple bolt-on neck comes pre-shaped with a comfortable C-profile. You will spend less time troubleshooting and more time building.
What you will learn: Basic soldering, 3-way switch wiring, bridge setup, string action adjustment.
Best for: Complete beginners, STEM classroom projects, young builders.
The E35 body shape with a center tone block gives you the warm, resonant character of a hollow body with the feedback resistance of a solid body. Two humbuckers deliver thick, smooth tone for jazz, blues, and indie rock. The arched maple top adds visual depth, especially under a sunburst or natural finish.
What you will learn: Humbucker wiring with coil splitting, finishing around f-holes, set-neck or bolt-on joint (depending on model), tone pot and capacitor selection.
Best for: Jazz and blues players, builders looking for a more advanced project, anyone who wants a visually striking instrument.
No headstock means better balance, lighter weight, and a modern look. Our headless kits feature a double-locking bridge and nut system that keeps tuning rock-solid. The mahogany or ash body pairs with a 24-fret neck for full two-octave access. High-output humbuckers handle drop tunings and high-gain tones without getting muddy.
What you will learn: Headless bridge mechanics, locking nut installation, high-output pickup wiring, extended-range setup.
Best for: Metal players, prog enthusiasts, builders who want something visually different from traditional guitar shapes.
A 34-inch scale length with a J-style pickup configuration is the most recorded bass sound in music. This kit gives you that classic growl with a modern build. The mahogany body provides deep lows with a natural midrange bump that cuts through a mix. Two single-coil pickups with volume-volume-tone wiring let you blend neck warmth with bridge bite.
What you will learn: Bass-specific setup (higher action, heavier strings), dual-pickup blending, intonation on a long scale, bass neck relief adjustment.
Best for: Bass players, band musicians who need a giggable instrument, builders who want to learn how scale length affects tone.
Set-neck construction is the most challenging joint to get right, and that is exactly why experienced builders choose it. The mahogany body with a carved maple top produces a thick, sustaining tone that rewards clean technique. Two humbuckers with push-pull coil splitting give you both warm, fat rhythm tones and bright single-coil leads from the same guitar.
What you will learn: Set-neck fitting and gluing, carved top finishing, push-pull pot wiring, binding work, advanced fret leveling.
Best for: Builders who have completed at least one kit, players who want maximum sustain and tonal depth.
Extended range without the complexity of an 8-string. Our 7-string kits add a low B string to the standard guitar tuning, opening up new chord voicings and riff possibilities. The extra string also means a wider neck, which teaches you about nut slotting and string spacing on a broader fretboard.
What you will learn: 7-string nut slotting, wide neck setup, extended range intonation, pickup height balancing across 7 strings.
Best for: Metal and djent players, experimenters, builders looking to expand their setup skills beyond 6 strings.
Best Acoustic-Electric: Acoustic Electric Semi-Hollow Kit
A thin semi-hollow body with a piezo pickup and onboard preamp gives you plugged-in acoustic tone without the bulk of a full-size acoustic. These kits teach you a completely different set of skills: piezo installation, preamp wiring, and acoustic-style bridge setup. The body is thinner than a traditional acoustic, making it comfortable for electric players crossing over.
What you will learn: Piezo pickup installation, preamp and EQ wiring, acoustic bridge setup, acoustic body finishing.
Best for: Singer-songwriters, worship musicians, players who want an acoustic-electric without the acoustic guitar build complexity.
Best Budget Build: Any Basswood ST or TE Kit Under 200 USD
You do not need to spend a lot to build a great guitar. Our basswood S-style and T-style kits start at 189.99 USD and include everything you need. Pair one with a 20 to 40 USD oil or spray-can finish, and your total investment is under 250 USD for a one-of-a-kind instrument. We have seen first-time builders produce guitars that sound and play as well as instruments costing three or four times more off the shelf.
Best for: Budget-conscious builders, first timers testing the waters, classroom and group build projects.
After helping thousands of first-time builders, here is the decision framework we recommend:
Never built anything? Start with a TE-style kit. Simplest wiring, most forgiving body shape.
Some DIY experience? The ST-style ash kit is the most versatile choice. You will learn more skills without being overwhelmed.
Want a challenge? Go for the single cutaway set-neck. Set-neck gluing and carved top finishing will test every skill you have.
Bass player? The JM-style bass is the only bass kit you need. Classic tone, proven design.
Every GKW kit includes a build difficulty score on the product page, so you know exactly what you are getting into before you buy. Check the build difficulty score guide to understand the rating system.
If you want to learn to build your own guitar, the fastest way is to do it beside someone who builds them for a living. Guitar Kit World supports in-person build workshops around the world, each one run by an...
Jamie Mangrum has built more guitars than he can count. We asked him whether a complete beginner can really build one worth being proud of, and he walked us through his entire set neck build, finishing schedule included.
Ten SAU students turned blank guitar kits into playable, personal electric guitars, then played them live at the class's second annual exhibit and jam.
