From Guitar Kits to Pergolas: 10 DIY Projects Every Man Will Enjoy
There's something deeply satisfying about building something with your own hands. Whether you've been tinkering in the garage for decades or you're finally ready to start that project you've been putting off, the right DIY build can be one of the most rewarding ways to spend a weekend, or a few of them.
We've rounded up 10 of the best DIY projects for men that are practical, enjoyable, and genuinely worth your time. Each one includes a video tutorial so you can see exactly what's involved before you commit.
1. Build Your Own Electric Guitar Kit
If you've ever picked up a guitar and thought, "I wonder what it'd be like to play one I built myself," a DIY guitar kit is the answer. Guitar kits come with a pre-shaped body, neck, hardware, pickups, and electronics, everything you need to assemble a fully playable instrument from scratch.
James with his DIY bass
You don't need luthier experience to get started. Most kits require basic tools: a screwdriver set, soldering iron, sandpaper, and some patience. The real magic happens when you choose your own finish, stain, paint, or natural oil, and make the guitar truly yours.
At Guitar Kit World, we offer over 40 body shapes with options for tonewoods, fretboard inlays, headstock styles, and hardware. Whether you want a classic LP-style, a sleek T-style, or something more adventurous like a semi-hollow or headless build, there's a kit that fits your playing style. Our step-by-step build guides walk you through every stage of assembly, finishing, and setup.
Watch: Full DIY Guitar Kit Build, Start to Finish
Browse Guitar Kits at Guitar Kit World
2. DIY Guitar Pedals
Building your own effects pedals is one of those hobbies that starts with curiosity and quickly becomes an obsession. A simple fuzz or overdrive pedal can be assembled in an afternoon with a soldering iron, a handful of components, and a pre-made PCB kit.
What makes DIY pedals appealing is the ability to clone legendary circuits, think Tube Screamer, Big Muff, or Klon Centaur, at a fraction of the retail cost. As your skills grow, you can start tweaking component values to shape your own signature tone. Companies like PedalPCB and DIY Guitar Pedals offer beginner-friendly kits with clear instructions.
This is a natural companion to a guitar kit build, and many builders end up doing both.
Watch: How to Build Your First DIY Guitar Pedal
3. DIY Standing Desk
A standing desk doesn't have to cost $800. With some plywood or hardwood, a set of adjustable desk legs (or even a manual crank frame), and a weekend's worth of work, you can build a standing desk tailored to your exact height and workspace.
The key measurements to get right are elbow height (your desk surface should sit at a 90–110 degree angle at the elbow) and monitor distance (20–26 inches from your eyes). A custom build lets you dial these in precisely, something off-the-shelf desks rarely achieve.
This is a great project for anyone who spends time at a computer, and it doubles as a solid introduction to furniture-building fundamentals.
Watch: DIY Standing Desk Build, Step by Step
4. DIY Pergola Kit
A pergola transforms a plain backyard into a space you actually want to spend time in. DIY pergola kits typically include pre-cut lumber, brackets, and hardware, so the focus is on assembly rather than complex carpentry.
Most pergola kits can be built in a weekend with a helper and standard power tools. Whether you're creating a shaded patio area, a garden walkway, or a structure for climbing vines, a pergola adds real value to your property and genuine enjoyment to your outdoor time.
Watch: How to Build a DIY Pergola
5. DIY Woodworking Bench
Every serious DIY builder eventually needs a proper workbench, and building your own is one of the most practical projects you can tackle. A sturdy bench with a flat top, built-in vise, and tool storage becomes the foundation for every project that follows.
You can build a solid workbench using construction-grade lumber (2x4s and plywood) for well under $200 in materials. The process teaches you joinery, squaring, and planning, skills that carry over to everything else you'll build.
Watch: Build a Professional Workbench on a Budget
6. DIY Fire Pit
A backyard fire pit is one of those projects that punches well above its weight in terms of enjoyment. A simple stone or brick fire pit can be built in a single afternoon with no mortar, no special tools, and about $150 in materials from your local hardware store.
The basic approach is straightforward: level a circular area, lay down gravel for drainage, and stack fire-rated bricks or retaining wall blocks in a ring. For a more permanent setup, you can set the first course into the ground and use construction adhesive between layers.
Watch: How to Build a Fire Pit, Easy DIY Project
7. DIY Bluetooth Speaker Build
For anyone who enjoys both woodworking and electronics, building a custom Bluetooth speaker is a deeply satisfying project. You get to design the enclosure, select quality drivers, wire up a Bluetooth amplifier board, and end up with a speaker that sounds better than most store-bought options.
Kits and parts are widely available from suppliers like Parts Express. The woodworking component can be as simple as a rectangular box or as creative as you want, some builders use reclaimed wood, cigar boxes, or even old ammo cans as enclosures.
Watch: How to Build a DIY Bluetooth Speaker from Scratch
8. DIY Knife Making
Knife making is one of those crafts that looks intimidating but is surprisingly accessible at the entry level. You can start with a pre-cut blade blank and focus on shaping the handle, fitting the pins, and finishing the edge, no forge required.
What draws many men to this hobby is the blend of precision and creativity. You choose the handle material (wood, micarta, bone), shape it by hand, and refine the edge to a razor finish. The end result is a functional tool with real craftsmanship behind it.
Watch: Beginner Knife Making, Complete Tutorial
9. DIY Leather Belt
Leatherworking is a quiet, focused craft that produces items you'll use every single day. A hand-stitched leather belt or bifold wallet makes an excellent first project, the materials are affordable, the tools are minimal, and the learning curve is gentle.
All you need to get started is a leather cutting mat, a stitching groover, a set of pricking irons, waxed thread, and a strip of quality vegetable-tanned leather. The hand-stitching technique (called saddle stitching) creates a stronger bond than machine sewing and gives the finished piece a distinctive handmade quality.
Watch: How to Make a Leather Belt, Beginner Leatherworking
10. DIY Home Bar Build
Building a home bar is a project that combines woodworking, finishing, and a bit of creativity into something you'll actually enjoy using, especially when friends come over. A basic L-shaped or straight bar can be built from plywood and trim for a few hundred dollars.
The project covers framing, adding a bar top (butcher block and epoxy-finished tops are both popular), installing a foot rail, and finishing with stain or paint. It's a multi-weekend build, but the result is a genuine conversation piece and gathering spot.
Watch: How to Build a DIY Home Bar
Which DIY Project Should You Start With?
If you're looking for something you can finish in a weekend, the fire pit and leather belt are great places to begin. If you want a longer, more immersive build, a guitar kit or home bar will keep you engaged over several weekends.
The best project is the one that genuinely interests you. Pick one, gather your tools, and get started, you'll be surprised how quickly the momentum builds from there.
Ready to Build Something?
If music is your thing, there's no better place to start than building your own guitar. At Guitar Kit World, we make it easy with over 40 kit styles, detailed build guides, and a builder support team that's ready to help if you get stuck.
Kalimar Maia building his next DIY guitar
Every kit includes the body, neck, hardware, pickups, and electronics, everything you need to build a guitar that's uniquely yours.
Browse DIY Guitar Kits → Get Started on Your Build Today
Related Products
Ready to Ship
🇺🇸 US Only
Alder Body Semi-hollow ST-style Guitar Kit with Quilted Maple Veneer
Original price $259.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
Build Skill 6/10 — Intermediate
Build Your Own Alder Body Semi-hollow ST-style Guitar Kit with Quilted Maple Veneer using our DIY Guitar Kits. Specifications Hand Orientation: Ri...
Ash L2 Baritone 30" Semi-Hollow Archtop Guitar Kit
Original price $319.99 USD
Current price $299.99 USD
$299.99 USD - $299.99 USD
Build Skill 7/10 — Intermediate
Build your own Ash body 30" Baritone Scale Semi-Hollow curved (arched) top LP-style guitar with Ebony Fretboard using this DIY Guitar Kit. Specific...
Pre-Order
🌍 Worldwide
Basswood ST style guitar kit with Maple Neck and Fretboard, Chrome Hardware
Original price $249.99 USD
Current price $189.99 USD
$189.99 USD - $189.99 USD
Build Skill 2/10 — Beginner
Build your own Basswood ST style guitar with Maple Neck and Fretboard, Chrome Hardware. You can find ST-style guitar building instructions here: ...
Ready to Ship
🌍 Worldwide
Blank Junior LP-style DIY Guitar Kit w/ Rosewood Fretboard
Original price $229.99 USD
Build Skill 8/10 — Advanced
Ready to Ship
🌍 Worldwide
Blank TE-style Guitar Kit w/ Rosewood Fretboard
Build a classic tone machine from the ground up with this blank TE-style guitar kit. Designed for makers who want full shaping, finishing, and tona...
