Telecaster® DIY Guitar Kits
The 'Tele®' Sound
Chris Cornell with Telecaster
  • Bolt-on 22 fret neck
Telecaster Neck Pickup
The Telecaster® Body
Thinline:
Deluxe:
Custom:
Unboxing a Blank Guitar Kit
