Types of pickups
Pickup positions
The neck position
The middle position
The bridge position
Playability
Paulo, a passionate guitar lover, motorcycle rider and the Builder Success Manager at Guitar Kit World, blends his in-depth technical expertise with his love for music to craft personalized solutions for builders...
Guitar Kits that don't need much soldering
Hey there, guitar enthusiast! So, you're on the hunt for a DIY guitar kit without the fuss of sol...
Luthier Tools for DIY Guitar Kits
A list of tools that can help DIY Guitar Builders assemble and finish kit guitars to a high stand...
Guitar binding is a decorative strip that covers the edge of the guitar's body, helping to protec...
Previous article How do you fix the guitar binding?
Next article How to check the neck alignment and neck angle
