{"product_id":"wide-neck-hollow-body-guitar-kit-48mm-nut","title":"Wide Neck Hollow Body Electric Guitar Kit with 48 mm Nut for Big Hands, Maple Body, Rosewood Fretboard, Single Humbucker","description":"\u003cp\u003e\u003cstrong\u003eA wide neck made for big hands.\u003c\/strong\u003e The nut is 48 mm wide, where a standard 6-string kit neck is about 42 mm, so the strings sit further apart and thick fingertips have room on every fret. The neck has a full U-profile, which fills the palm instead of thinning out under it. If chords feel cramped on a regular neck, this is the kit built for you.\u003c\/p\u003e\n\u003cp\u003eAround that neck: a fully hollow maple body with two f-holes and multi-ply binding, a set-in maple neck with a bound rosewood fretboard and abalone pearloid trapezoid inlays, a bone nut, one chrome-covered neck humbucker, a floating bridge and a chrome trapeze tailpiece. One pickup and two knobs keep the wiring simple.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (6\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eFloating bridge has no fixed posts, so you position it by measuring the scale length\u003c\/li\u003e\n\u003cli\u003eSet-in neck has to be aligned and glued before finishing, the step that most affects intonation\u003c\/li\u003e\n\u003cli\u003eOne pickup and a pre-assembled pot and jack harness keep the soldering short\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eLaminated Maple\u003c\/strong\u003e (top, back and sides)\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eHollow Body\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSound Holes: \u003cstrong\u003e2 f-holes\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInternal Support: \u003cstrong\u003eBridge block, Maple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle Florentine style\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eMulti-ply Ivory\u003c\/strong\u003e (top and back)\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eSet-in\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eU-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e (adjusted at the headstock)\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle Ivory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eTrapezoid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eAbalone Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eClassic Blues, 3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e (pre-installed)\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e48 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (chrome cover)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 1 Tone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY\u003c\/strong\u003e (soldering required)\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/single-humbucker-wiring-diagram-1-volume-1-tone\" target=\"_blank\" rel=\"noopener\"\u003eSingle Humbucker, 1 Volume, 1 Tone\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eFloating Archtop Bridge\u003c\/strong\u003e (wooden base, adjustable saddles)\u003c\/li\u003e\n\u003cli\u003eTailpiece: \u003cstrong\u003eTrapeze\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e (truss rod cover)\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eUnfinished fully hollow maple body with two f-holes, multi-ply binding, a routed neck pickup cavity, two control holes, a side jack hole and a routed neck pocket\u003c\/li\u003e\n\u003cli\u003eUnfinished maple neck with a bound rosewood fretboard, abalone pearloid trapezoid inlays, a pre-installed 48 mm bone nut and a drilled 3+3 headstock\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003e1x chrome-covered humbucker with mounting ring and screws\u003c\/li\u003e\n\u003cli\u003e1x wiring harness with volume and tone pots and output jack\u003c\/li\u003e\n\u003cli\u003e1x floating bridge with wooden base and chrome adjustable saddles\u003c\/li\u003e\n\u003cli\u003e1x chrome trapeze tailpiece with mounting screws\u003c\/li\u003e\n\u003cli\u003e2x chrome knobs\u003c\/li\u003e\n\u003cli\u003e1x black pickguard with mounting hardware\u003c\/li\u003e\n\u003cli\u003e1x black truss rod cover with screws\u003c\/li\u003e\n\u003cli\u003eAssorted chrome nuts, washers and mounting screws\u003c\/li\u003e\n\u003cli\u003e1x Allen wrench\u003c\/li\u003e\n\u003cli\u003e1x guitar cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the pickup to the harness. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set, wood glue and clamps (for the set-in neck)\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, ruler or tape measure for bridge placement, Allen wrench for the truss rod\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eCompare it with our \u003ca href=\"\/products\/x-braced-hollow-body-guitar-kit-ebony-single-humbucker\"\u003eX-braced hollow body kit\u003c\/a\u003e, or browse the full range of \u003ca href=\"\/collections\/hollow-body\"\u003ehollow body guitar kits\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – U.S. \u0026 International Warehouses","offer_id":67645306830982,"sku":"E75-RSSC-5104","price":254.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-wide-neck-hollow-body-guitar-kit-48mm-nut-complete-kit-e75-rssc-5104.jpg?v=1791617149","url":"https:\/\/guitarkitworld.com\/products\/wide-neck-hollow-body-guitar-kit-48mm-nut","provider":"Guitar Kit World","version":"1.0","type":"link"}
