{"product_id":"spalted-maple-semi-hollow-guitar-kit-two-humbuckers","title":"Spalted Maple Thin Semi-Hollow Single-Cutaway Electric Guitar Kit with Two Humbuckers, Ash Body, Maple Fretboard","description":"\u003ch4\u003eWhat Makes This Kit Different\u003c\/h4\u003e\n\u003cp\u003e\u003cstrong\u003eA spalted maple top and two humbuckers on a thin semi-hollow ash body.\u003c\/strong\u003e Spalted maple is pale maple marked with dark natural lines, and every sheet is different, so no two of these tops look alike. The veneer is glued to the top of a chambered ash body with one f-hole and a black binding line around the top edge. Two chrome-covered humbuckers sit in a large white pearl pickguard, in place of the two single-coils on our \u003ca href=\"\/products\/semi-hollow-ash-t-style-guitar-kit\"\u003etwo single-coil spalted maple semi-hollow kit\u003c\/a\u003e.\u003c\/p\u003e\n\u003cp\u003eAround that body: a bolt-on maple neck with a maple fretboard and black dot inlays, 21 frets with rounded fret ends, a chrome six-saddle hardtail bridge with the strings loaded through the back of the body, chrome sealed tuners and a pre-assembled volume, tone and 3-way blade switch harness.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (6\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eSpalted maple veneer is thin and easy to sand through, so use a light touch at the edges and around the f-hole\u003c\/li\u003e\n\u003cli\u003eAsh has open grain that needs filling before finishing for a smooth result\u003c\/li\u003e\n\u003cli\u003eTwo humbuckers mean more solder joints than a single-pickup kit, but the pots, switch and jack come pre-assembled\u003c\/li\u003e\n\u003cli\u003eHardtail bridge has no tremolo to set up, and the headstock is already shaped with its tuner holes drilled\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eAsh\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood, chambered\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSemi-Hollow Chambered\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSound Holes: \u003cstrong\u003e1 f-hole\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInternal Support: \u003cstrong\u003eNone (chambered body)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle Black\u003c\/strong\u003e (top edge)\u003c\/li\u003e\n\u003cli\u003eTop Veneer: \u003cstrong\u003eSpalted Maple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e (4 screws and neck plate)\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eAdjustable\u003c\/strong\u003e (adjusted at the headstock end)\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e648 mm \/ 25.5\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e21\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Ends: \u003cstrong\u003eRounded\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDot\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eBlack Plastic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eYes\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eStandard 6-in-line (as in product images)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Holes: \u003cstrong\u003ePre-drilled\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eWhite Plastic\u003c\/strong\u003e (pre-installed)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker, chrome cover\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker, chrome cover\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 1 Tone, 3-Way Blade Switch\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY\u003c\/strong\u003e (soldering required)\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-1-volume-1-tone-3-way-switch\" target=\"_blank\" rel=\"noopener\"\u003eHH, 1 Volume, 1 Tone, 3-Way Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eHardtail, 6 saddles, string-through body\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eWhite Pearl\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eChrome dome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x unfinished semi-hollow ash body with spalted maple veneer top, one f-hole and black top binding\u003c\/li\u003e\n\u003cli\u003e1x white pearl pickguard with two chrome-covered humbuckers mounted\u003c\/li\u003e\n\u003cli\u003e1x maple neck with maple fretboard, 21 frets, black dot inlays and a drilled headstock\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings, washers and screws\u003c\/li\u003e\n\u003cli\u003e1x chrome six-saddle hardtail bridge\u003c\/li\u003e\n\u003cli\u003e6x string ferrules for the back of the body\u003c\/li\u003e\n\u003cli\u003e1x pre-assembled control harness with volume and tone pots, 3-way blade switch and output jack\u003c\/li\u003e\n\u003cli\u003e2x chrome dome knobs\u003c\/li\u003e\n\u003cli\u003e1x black switch tip\u003c\/li\u003e\n\u003cli\u003e1x chrome jack plate\u003c\/li\u003e\n\u003cli\u003e1x chrome neck plate with four neck screws\u003c\/li\u003e\n\u003cli\u003e2x strap buttons\u003c\/li\u003e\n\u003cli\u003e2x Allen wrenches\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003e1x guitar cable\u003c\/li\u003e\n\u003cli\u003eAssorted mounting screws\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/semi-hollow-te-style-guitar-kits\"\u003esemi-hollow single-cutaway guitar kits\u003c\/a\u003e and \u003ca href=\"\/collections\/spalted-maple-guitar-kits\"\u003espalted maple guitar kits\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67624266989702,"sku":"TEH-RSAB-2","price":259.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-spalted-maple-semi-hollow-guitar-kit-two-humbuckers-complete-kit-teh-rsab-2-stamped.jpg?v=1791214462","url":"https:\/\/guitarkitworld.com\/products\/spalted-maple-semi-hollow-guitar-kit-two-humbuckers","provider":"Guitar Kit World","version":"1.0","type":"link"}
