{"product_id":"skunk-stripe-neck-offset-guitar-kit-mahogany-bound-rosewood","title":"Skunk-Stripe Neck Offset Electric Guitar Kit with Bound Rosewood Fretboard, Mahogany Body, Rhythm and Lead Circuit","description":"\u003cp\u003e\u003cstrong\u003eA skunk-stripe maple neck with a bound rosewood fretboard, on a solid mahogany offset body.\u003c\/strong\u003e The skunk stripe is the dark strip down the back of the neck. It covers the slot for the truss rod, so the fretboard face stays one clean piece. Ivory binding runs along both edges of the fretboard, with the side dots set into it. The frets are in and the headstock is drilled.\u003c\/p\u003e\n\u003cp\u003eThe ivory pickguard holds the full rhythm and lead circuit. The slide switch, the 3-way toggle and the rhythm controls are already mounted. You solder in the two P90 pickups. The 24 in (610 mm) scale is shorter than a 25.5 in neck, so the frets sit closer together. There are 21 stainless-steel frets with dot inlays. A six-saddle bridge pairs with a chrome floating vibrato. The tuners are sealed and the hardware is chrome. The mahogany body has no veneer, so it is ready for any stain, paint or clear coat.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (5\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eThe floating vibrato tailpiece needs careful setup so the guitar stays in tune\u003c\/li\u003e\n\u003cli\u003eMahogany has open grain that needs filling before finishing for a smooth result\u003c\/li\u003e\n\u003cli\u003eThe flat slab body is straightforward to sand, and every cavity and hole is pre-cut\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eDouble (offset)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple with Skunk Stripe\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Adjustment: \u003cstrong\u003eHeadstock\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e610 mm \/ 24\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle, Ivory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e21\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo (2.7 x 0.9 mm \/ 0.106 x 0.036\")\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDot\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Plastic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eStandard (as in product images)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Layout: \u003cstrong\u003e6-in-line\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eWhite Plastic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eP90\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eP90\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 1 Tone, 3-Way Toggle, Rhythm Circuit (1 Volume, 1 Tone), Slide Switch\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/offset-wiring-diagram-rhythm-lead-2-volume-2-tone-slide-switch\" target=\"_blank\" rel=\"noopener\"\u003eOffset Rhythm and Lead Circuit, 2 Volume, 2 Tone, Slide Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eAdjustable Bridge + Vibrato Tailpiece\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed, Diecast\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eIvory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x unfinished solid mahogany offset body\u003c\/li\u003e\n\u003cli\u003e1x skunk-stripe maple neck with bound rosewood fretboard (frets installed), dot inlays and a drilled headstock\u003c\/li\u003e\n\u003cli\u003e1x ivory pickguard with slide switch, toggle switch and rhythm circuit pre-installed\u003c\/li\u003e\n\u003cli\u003e2x ivory P90 pickups with exposed pole pieces\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings, washers and mounting screws\u003c\/li\u003e\n\u003cli\u003e1x chrome control plate\u003c\/li\u003e\n\u003cli\u003e1x chrome floating vibrato tailpiece with arm\u003c\/li\u003e\n\u003cli\u003e1x chrome bridge with six adjustable saddles\u003c\/li\u003e\n\u003cli\u003e1x chrome jack cup with output jack\u003c\/li\u003e\n\u003cli\u003e2x chrome control knobs\u003c\/li\u003e\n\u003cli\u003e2x springs\u003c\/li\u003e\n\u003cli\u003e2x Allen wrenches\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003e2x black strap buttons\u003c\/li\u003e\n\u003cli\u003e1x guitar cable with one angled plug\u003c\/li\u003e\n\u003cli\u003e2 bags of assorted screws and small parts\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eCompare it with the \u003ca href=\"\/products\/jg-style-mahogany-guitar-kit-rosewood-fretboard\"\u003eblock-inlay mahogany offset kit with a tortoise pickguard\u003c\/a\u003e or the \u003ca href=\"\/products\/short-scale-offset-diy-guitar-kit-mahogany\"\u003edual-humbucker mahogany offset kit\u003c\/a\u003e, or browse the full range of \u003ca href=\"\/collections\/offset-guitar-kits\"\u003eoffset guitar kits\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":41115425996934,"sku":"JG-RMRC-5231","price":259.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/Firebirdstyleguitarkit_1.jpg?v=1715154903","url":"https:\/\/guitarkitworld.com\/products\/skunk-stripe-neck-offset-guitar-kit-mahogany-bound-rosewood","provider":"Guitar Kit World","version":"1.0","type":"link"}
