{"product_id":"short-scale-offset-diy-guitar-kit-mahogany-black-hardware","title":"Short-scale JG style Guitar Kit with Mahogany Body, Rosewood Fretboard, Black Hardware","description":"\u003cp\u003eBuild a short-scale offset electric guitar from a box of parts. This DIY kit gives you a mahogany body, a bolt-on neck with a 22-fret rosewood fretboard, and two humbuckers you wire yourself. The 24-inch scale plays fast and comfortable, and the floating vibrato tailpiece adds expressive pitch bends once you set it up.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eOrientation: \u003cstrong\u003eRight-handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e610 mm \/ 24\"\u003c\/strong\u003e (short scale)\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty\u003c\/h5\u003e\n\u003cp\u003e\u003cstrong\u003eIntermediate\u003c\/strong\u003e (5\/10)\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eDIY wiring of the offset rhythm and lead circuits means soldering multiple slide switches and pots\u003c\/li\u003e\n\u003cli\u003eFloating vibrato tailpiece and Tune-O-Matic bridge need careful intonation and setup\u003c\/li\u003e\n\u003cli\u003eBolt-on neck and fully pre-routed body keep the assembly itself beginner-friendly\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e (2-3 pcs)\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eDouble\u003c\/strong\u003e (offset)\u003c\/li\u003e\n\u003cli\u003eBody Binding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e (2 pcs)\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e12\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDot\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003ePearl White\u003c\/strong\u003e (Engineered)\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eS-style 6-in-line\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Holes: \u003cstrong\u003e10mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eWhite Plastic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e42mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 1 Tone, offset-style rhythm and lead circuit with slide switches\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY\u003c\/strong\u003e (soldering required)\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eTop jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eBlack Tune-O-Matic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTailpiece: \u003cstrong\u003eBlack floating vibrato tailpiece\u003c\/strong\u003e (with arm)\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eBlack sealed diecast\u003c\/strong\u003e (6-in-line)\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eDouble-action adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4 style=\"margin-top: 24px;\"\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eOffset mahogany body (unfinished)\u003c\/li\u003e\n\u003cli\u003eMahogany neck with rosewood fretboard (unfinished)\u003c\/li\u003e\n\u003cli\u003e2x humbucker pickups (black, open-coil)\u003c\/li\u003e\n\u003cli\u003eWiring components (2 pots, slide switches, output jack, wiring - soldering required)\u003c\/li\u003e\n\u003cli\u003eBlack Tune-O-Matic bridge\u003c\/li\u003e\n\u003cli\u003eBlack floating vibrato tailpiece with arm\u003c\/li\u003e\n\u003cli\u003e6x black sealed diecast tuners with mounting hardware\u003c\/li\u003e\n\u003cli\u003eWhite plastic nut\u003c\/li\u003e\n\u003cli\u003eBlack pickguard\u003c\/li\u003e\n\u003cli\u003e2x black control knobs\u003c\/li\u003e\n\u003cli\u003eBlack neck plate with screws\u003c\/li\u003e\n\u003cli\u003eMounting screws and hardware\u003c\/li\u003e\n\u003cli\u003eAllen wrench (truss rod adjustment)\u003c\/li\u003e\n\u003cli\u003eStrings\u003c\/li\u003e\n\u003cli\u003eGuitar cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4 style=\"margin-top: 24px;\"\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eThis kit requires soldering for the electronics. Depending on the finish and build you have in mind, you may need:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire strippers\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat (polyurethane or nitrocellulose lacquer)\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":43716724129926,"sku":"JG-RMRB-5103","price":219.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-jg-style-diy-guitar-kit-complete-jg-rmrb-5103.jpg?v=1780922232","url":"https:\/\/guitarkitworld.com\/products\/short-scale-offset-diy-guitar-kit-mahogany-black-hardware","provider":"Guitar Kit World","version":"1.0","type":"link"}
