{"product_id":"red-pearloid-gold-single-cutaway-guitar-kit-bound-maple-fretboard","title":"Red Pearloid Pickguard Single-Cutaway Electric Guitar Kit with Gold Hardware, Bound Maple Fretboard, Two Single-Coils","description":"\u003cp\u003e\u003cstrong\u003eA red pearloid pickguard and gold hardware on a classic single-cutaway body, with a bound maple fretboard.\u003c\/strong\u003e The red pearloid pickguard comes already fitted to the body with the gold-covered neck pickup mounted on it. Every metal part in the kit is gold: the six sealed tuners, the bridge plate and its six saddles, the control plate and both knobs, the neck pickup cover, the output jack plate, the strap buttons and the screws. An ivory binding strip runs along both edges of the maple fretboard, set off by black dot inlays.\u003c\/p\u003e\n\u003cp\u003eThe maple neck bolts on with four screws and carries 22 frets, black dot inlays, black side dots and a pointed 6-in-line headstock with a pre-slotted nut. Two single-coil pickups (a gold-covered neck pickup and a bridge pickup set in the gold bridge plate) run through 1 volume, 1 tone and a 3-way blade switch on the gold control plate. The body is plain wood with no veneer and no body binding, so it takes paint, stain or a clear finish directly.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Beginner (3\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eThe pickups and jack are soldered to the control plate's terminal board, so you need a soldering iron and some care with each joint\u003c\/li\u003e\n\u003cli\u003eSix individual bridge saddles have to be set for string height and intonation during setup\u003c\/li\u003e\n\u003cli\u003eBolt-on neck, pre-cut cavities and a pickguard already fitted to the body keep the woodwork simple\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eBasswood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e (adjusted at the headstock)\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e648 mm \/ 25.5\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle Ivory\u003c\/strong\u003e (fretboard edges)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDot\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eBlack Plastic (ABS)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003ePointed, 6-in-line\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e (pre-slotted)\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e42 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eSingle Coil\u003c\/strong\u003e (gold cover)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eTE-Style\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 1 Tone, 3-Way Blade Switch\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/2x-single-coil-wiring-diagram-1-volume-1-tone-3-way-selector\" target=\"_blank\" rel=\"noopener\"\u003e2x Single Coil, 1 Volume, 1 Tone, 3-Way Selector\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eTE-Style Bridge (top-loading)\u003c\/strong\u003e (6 adjustable saddles)\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed Diecast\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eRed Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControl Plate: \u003cstrong\u003eGold\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eGold Knurled Dome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eGold\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x basswood body with single cutaway, routed for the neck pickup, bridge plate and control plate (unfinished)\u003c\/li\u003e\n\u003cli\u003e1x red pearloid pickguard fitted to the body, carrying a gold-covered single-coil neck pickup\u003c\/li\u003e\n\u003cli\u003e1x maple neck with bound maple fretboard, 22 frets, black dot inlays and a fitted nut (unfinished)\u003c\/li\u003e\n\u003cli\u003e6x gold sealed tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003e1x gold bridge plate with a bridge single-coil pickup and 6 adjustable saddles\u003c\/li\u003e\n\u003cli\u003e1x gold control plate with 3-way blade switch, 2 gold knurled knobs and a wiring terminal board\u003c\/li\u003e\n\u003cli\u003e1x gold output jack plate with jack socket\u003c\/li\u003e\n\u003cli\u003e1x neck plate with 4 gold mounting screws\u003c\/li\u003e\n\u003cli\u003e2x gold strap buttons with felt washers\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003e2x Allen wrenches\u003c\/li\u003e\n\u003cli\u003e1x instrument cable\u003c\/li\u003e\n\u003cli\u003eAssorted gold mounting screws\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eCompare it with the \u003ca href=\"\/products\/te-style-guitar-kit-basswood-maple-single-coils\"\u003ebasswood single-cutaway kit with a maple fretboard\u003c\/a\u003e and the \u003ca href=\"\/products\/mahogany-te-guitar-kit-rosewood-fretboard-pre-wired\"\u003epre-wired mahogany single-cutaway kit\u003c\/a\u003e, or browse the full range of \u003ca href=\"\/collections\/te-guitar-kits\"\u003esingle-cutaway guitar kits\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67654202228870,"sku":"TE-RMRG-5190","price":219.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-gold-hardware-single-cutaway-diy-guitar-kit-complete-kit-te-rmrg-5190.jpg?v=1791736842","url":"https:\/\/guitarkitworld.com\/products\/red-pearloid-gold-single-cutaway-guitar-kit-bound-maple-fretboard","provider":"Guitar Kit World","version":"1.0","type":"link"}
