{"product_id":"marblo-double-cutaway-guitar-kit-double-locking-tremolo-quilted-maple","title":"Marblo Double-Cutaway Electric Guitar Kit with Double-Locking Tremolo and 4+2 Headstock, Quilted Maple Veneer, Basswood Body, Maple Fretboard","description":"\u003ch4\u003eWhat Makes This Kit Different\u003c\/h4\u003e\n\u003cp\u003e\u003cstrong\u003eA double-cutaway body with a 4+2 headstock and a double-locking tremolo, in one kit.\u003c\/strong\u003e The tremolo locks the strings at the bridge and the locking nut clamps them at the headstock, so the guitar stays in tune through heavy whammy use once it is set up. The locking nut comes already fitted to the neck, and the body is pre-routed for the floating tremolo, its springs and both humbuckers.\u003c\/p\u003e\n\u003cp\u003eThe basswood body carries a quilted maple veneer on the top, ready for a clear, stained or burst finish of your choice. The bolt-on maple neck has a maple fretboard with 22 frets, black dot inlays, side dots and rounded fret ends. Two zebra humbuckers run through a single volume knob and a 3-way toggle, with chrome hardware throughout.\u003c\/p\u003e\n\n\u003cp\u003eMarblo is a name we built from marble, the stone that wears smooth and round. The body has the same soft outline: two short rounded horns, a full lower bout and no sharp points. The quilted maple top is left bare for you to finish your way.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (6\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eSetting up the floating double-locking tremolo: spring tension, string locking and fine tuners take patience.\u003c\/li\u003e\n\u003cli\u003eThe quilted maple veneer is thin, so sand the top lightly and by hand to avoid sanding through.\u003c\/li\u003e\n\u003cli\u003eSoldering two humbuckers to one volume pot and a 3-way toggle.\u003c\/li\u003e\n\u003cli\u003eEasier than a set-neck build: the bolt-on neck, the pre-cut routes and the pre-fitted locking nut take care of the woodwork.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eBasswood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eDouble\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop Veneer: \u003cstrong\u003eQuilted Maple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e (4 screws)\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eAdjustable\u003c\/strong\u003e (adjusted at the heel)\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e648 mm \/ 25.5\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Ends: \u003cstrong\u003eRounded\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDot\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Color: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eYes\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eTuner Layout: \u003cstrong\u003e4+2\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Holes: \u003cstrong\u003ePre-drilled\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eLocking nut, pre-installed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (zebra, with mounting ring)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (zebra, with mounting ring)\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 3-way toggle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY\u003c\/strong\u003e (soldering required)\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-1-volume-3-way-toggle-no-tone\" target=\"_blank\" rel=\"noopener\"\u003eHH, 1 Volume, 3-Way Toggle, No Tone\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eDouble-locking tremolo\u003c\/strong\u003e (floating, with fine tuners and whammy arm)\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003e6 sealed tuners\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003e1 chrome dome knob\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e (tremolo and control cavities)\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eIncluded\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x Basswood body with quilted maple veneer, pre-routed\u003c\/li\u003e\n\u003cli\u003e1x Maple neck with maple fretboard and pre-installed locking nut\u003c\/li\u003e\n\u003cli\u003e6x Tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003e2x Zebra humbuckers with mounting rings, springs and screws\u003c\/li\u003e\n\u003cli\u003e1x Volume pot, 1x 3-way toggle switch and wiring\u003c\/li\u003e\n\u003cli\u003e1x Output jack with plate\u003c\/li\u003e\n\u003cli\u003e1x Chrome dome knob\u003c\/li\u003e\n\u003cli\u003e1x Double-locking tremolo with 2x anchor studs and whammy arm\u003c\/li\u003e\n\u003cli\u003e3x Tremolo springs, 1x spring claw and screws\u003c\/li\u003e\n\u003cli\u003e1x String retainer bar\u003c\/li\u003e\n\u003cli\u003e4x Neck screws with ferrules\u003c\/li\u003e\n\u003cli\u003e2x Strap buttons\u003c\/li\u003e\n\u003cli\u003e1x Tremolo cavity cover and 1x control cavity cover, with screws\u003c\/li\u003e\n\u003cli\u003eAllen keys for the tremolo and locking nut\u003c\/li\u003e\n\u003cli\u003e1x Set of strings\u003c\/li\u003e\n\u003cli\u003e1x Guitar cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod adjustment and tremolo setup\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\n\u003cp\u003eCompare our other double-locking tremolo kits: the \u003ca href=\"\/products\/pr-guitar-kit-tremolo-quilted-maple\"\u003eset-neck kit with quilted maple veneer\u003c\/a\u003e and the \u003ca href=\"\/products\/super-st-guitar-kit-vinework-fretboard-inlays\"\u003emahogany kit with vinework inlays\u003c\/a\u003e. Or browse the full range of \u003ca href=\"\/collections\/quilted-maple-guitar-kits\"\u003equilted maple guitar kits\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67624288682118,"sku":"MA-RBPC-1","price":236.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-marblo-double-locking-tremolo-quilted-maple-guitar-kit-complete-kit-flat-lay-ma-rbpc-1.jpg?v=1791219630","url":"https:\/\/guitarkitworld.com\/products\/marblo-double-cutaway-guitar-kit-double-locking-tremolo-quilted-maple","provider":"Guitar Kit World","version":"1.0","type":"link"}
