{"product_id":"locking-tremolo-v-shape-guitar-kit-lightning-bolt-inlays-mahogany","title":"Wingspan V-Shape Electric Guitar Kit with Locking Tremolo and Lightning Bolt Inlays, Mahogany Body, Rosewood Fretboard, Humbuckers","description":"\u003cp\u003e\u003cstrong\u003eA locking tremolo and a locking nut on a V-shaped mahogany body, with lightning bolt inlays on a rosewood fretboard.\u003c\/strong\u003e The locking tremolo clamps each string at the bridge, and the locking nut clamps all six at the top of the neck. Once both are tightened, you can work the tremolo arm hard and the strings stay in tune, and fine tuners on the bridge take care of small adjustments. The pickup, bridge and spring cavities are already routed, so the hardware drops straight in.\u003c\/p\u003e\n\u003cp\u003eThe rest of the kit: a bolt-on maple neck with 22 frets and white pearloid lightning bolt inlays, two chrome-covered humbuckers with 1 volume, 2 tone and a 3-way switch, a side-mounted output jack and chrome sealed tuners on a pointed 3+3 headstock.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (5\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eThe locking tremolo has to be balanced against its springs, then the nut clamped once the guitar is in tune: the step that takes the most care\u003c\/li\u003e\n\u003cli\u003eMahogany has open grain that needs filling before finishing for a smooth result\u003c\/li\u003e\n\u003cli\u003eThe neck bolts on with four screws, so there is no gluing or clamping to get right\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eDouble\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Adjustment: \u003cstrong\u003eHeadstock\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo (2.7 x 0.9 mm \/ 0.106 x 0.036\")\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eLightning Bolt\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eStandard (as in product images)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eLocking Nut\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 2 Tone, 3-Way\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-1-volume-2-tone-3-way-switch\" target=\"_blank\" rel=\"noopener\"\u003eHH, 1 Volume, 2 Tone, 3-Way Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eLocking Tremolo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eChrome Sealed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eV-shaped mahogany guitar body (unfinished), pre-routed for two humbuckers, the tremolo and the springs\u003c\/li\u003e\n\u003cli\u003eBolt-on maple neck with rosewood fretboard, white pearloid lightning bolt inlays and locking nut fitted\u003c\/li\u003e\n\u003cli\u003eChrome locking tremolo bridge with fine tuners, two mounting studs and tremolo arm\u003c\/li\u003e\n\u003cli\u003e3x tremolo springs\u003c\/li\u003e\n\u003cli\u003eString retainer bar\u003c\/li\u003e\n\u003cli\u003e2x chrome-covered humbuckers with black mounting rings\u003c\/li\u003e\n\u003cli\u003e3 pots and a 3-way switch\u003c\/li\u003e\n\u003cli\u003e3x black knobs\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003eChrome neck plate with 4 neck screws\u003c\/li\u003e\n\u003cli\u003eChrome recessed output jack plate with jack\u003c\/li\u003e\n\u003cli\u003eBlack control cavity cover, black spring cover and black truss rod cover\u003c\/li\u003e\n\u003cli\u003e2x strap buttons\u003c\/li\u003e\n\u003cli\u003eStrings\u003c\/li\u003e\n\u003cli\u003eGuitar cable\u003c\/li\u003e\n\u003cli\u003eAllen wrenches\u003c\/li\u003e\n\u003cli\u003eAssorted mounting screws\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrenches for the truss rod, the locking nut and the tremolo\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/v-guitar-kits\"\u003eV-shaped guitar kits\u003c\/a\u003e, or compare the \u003ca href=\"\/products\/mahogany-v3-guitar-kit\"\u003emahogany V kit with a stopbar bridge\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67788975931526,"sku":"V2-RMRC-5042","price":259.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-v-shape-locking-tremolo-diy-guitar-kit-complete-pointed-headstock-v2-rmrc-5042.jpg?v=1795424793","url":"https:\/\/guitarkitworld.com\/products\/locking-tremolo-v-shape-guitar-kit-lightning-bolt-inlays-mahogany","provider":"Guitar Kit World","version":"1.0","type":"link"}
