{"product_id":"left-handed-hookline-guitar-kit-trapezoid-inlays-mahogany","title":"Left-Handed Hookline Electric Guitar Kit with Trapezoid Inlays, Mahogany Body, Rosewood Fretboard, Humbuckers","description":"\u003cp\u003e\u003cstrong\u003eA left-handed Hookline guitar kit: a pointed single-cutaway mahogany body built as a true lefty, with white pearloid trapezoid inlays on a rosewood fretboard.\u003c\/strong\u003e The body, neck pocket, pickup routes and control cavity are all cut for left-handed playing, and the neck carries a left-handed 6-in-line headstock, so nothing has to be flipped or re-drilled. The pickup, control and switch cavities are already routed, so the hardware drops straight in.\u003c\/p\u003e\n\n\u003cp\u003eThe rest of the kit: a bolt-on mahogany neck with 22 frets, two open humbuckers with 2 volume, 2 tone and a 3-way toggle switch, a Tune-o-matic bridge with a stopbar tailpiece, a side-mounted output jack and chrome sealed tuners.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eLeft-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Beginner (4\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMahogany has open grain that needs filling before finishing for a smooth result\u003c\/li\u003e\n\u003cli\u003eFour pots and a toggle switch mean more soldered joints to keep tidy\u003c\/li\u003e\n\u003cli\u003eThe neck bolts on with four screws, so there is no gluing or clamping to get right\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e (2-3 pieces)\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Adjustment: \u003cstrong\u003eHeadstock\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo (2.7 x 0.9 mm \/ 0.106 x 0.036\")\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eTrapezoid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eStandard (as in product images)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Layout: \u003cstrong\u003e6-in-line\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e42 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickup Magnets: \u003cstrong\u003eCeramic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 2 Tone, 3-Way Toggle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-2-volume-2-tone-3-way-toggle-switch\" target=\"_blank\" rel=\"noopener\"\u003eHH, 2 Volume, 2 Tone, 3-Way Toggle Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eTune-o-matic\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTailpiece: \u003cstrong\u003eStopbar\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eChrome Sealed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eChrome Dome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eLeft-handed Hookline mahogany guitar body (unfinished), pre-routed for two humbuckers, the controls and the switch\u003c\/li\u003e\n\u003cli\u003eLeft-handed bolt-on mahogany neck with rosewood fretboard, white pearloid trapezoid inlays and nut fitted\u003c\/li\u003e\n\u003cli\u003eTune-o-matic bridge in chrome, with two posts and anchors\u003c\/li\u003e\n\u003cli\u003eChrome stopbar tailpiece with two studs and anchors\u003c\/li\u003e\n\u003cli\u003e2x open humbuckers with black mounting rings\u003c\/li\u003e\n\u003cli\u003e4 pots and a 3-way toggle switch\u003c\/li\u003e\n\u003cli\u003e4x chrome dome knobs\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003eChrome neck plate with 4 neck screws\u003c\/li\u003e\n\u003cli\u003eChrome side output jack plate with jack\u003c\/li\u003e\n\u003cli\u003eBlack control cavity cover, black switch cavity cover and black truss rod cover\u003c\/li\u003e\n\u003cli\u003e2x strap buttons\u003c\/li\u003e\n\u003cli\u003eStrings\u003c\/li\u003e\n\u003cli\u003eGuitar cable\u003c\/li\u003e\n\u003cli\u003eAllen wrench\u003c\/li\u003e\n\u003cli\u003eAssorted mounting screws\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for the truss rod\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/hookline-guitar-kits\"\u003eHookline guitar kits\u003c\/a\u003e and \u003ca href=\"\/collections\/left-handed-diy-guitar-kits\"\u003eleft-handed guitar kits\u003c\/a\u003e, or compare the right-handed \u003ca href=\"\/products\/hookline-mahogany-ebony-guitar-kit\"\u003eHookline kit with an ebonized fretboard\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67788976324742,"sku":"HKL1-LMRC-5440","price":229.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-left-handed-hookline-diy-guitar-kit-01-complete-kit-hkl1-lmrc-5440.jpg?v=1795426683","url":"https:\/\/guitarkitworld.com\/products\/left-handed-hookline-guitar-kit-trapezoid-inlays-mahogany","provider":"Guitar Kit World","version":"1.0","type":"link"}
