{"product_id":"hookline-flamed-maple-rosewood-gold-guitar-kit","title":"Hookline Single-Cutaway Electric Guitar Kit, Flamed Maple Veneer, Mahogany Body, Set-In Mahogany Neck, Rosewood Fretboard, Gold Hardware","description":"\u003cp\u003eA set-in-neck DIY guitar kit built on our Hookline body, a pointed single-cutaway whose lower bout sweeps into a downward hook, topped with a flamed maple veneer. Solid mahogany body and mahogany neck, a bound rosewood fretboard with pearl-white parallelogram inlays, multi-ply ivory body binding and a full gold hardware set. The veneer takes a translucent stain or burst beautifully. The electronics ship loose rather than pre-wired, so this build includes soldering.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eOrientation: \u003cstrong\u003eRight-handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty\u003c\/h5\u003e\n\u003cp\u003e\u003cstrong\u003eIntermediate\u003c\/strong\u003e (7\/10)\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eSet-in neck joint requires gluing and clamping, and the fit must be checked before glue-up\u003c\/li\u003e\n\u003cli\u003eElectronics are not pre-wired, so soldering is required for pickups, pots, switch and jack\u003c\/li\u003e\n\u003cli\u003eThe flamed maple veneer is thin, so sand lightly and never power-sand the top, or you will cut through the figure\u003c\/li\u003e\n\u003cli\u003eMulti-ply body binding and bound fretboard must be masked carefully when finishing\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop Veneer: \u003cstrong\u003eFlamed Maple\u003c\/strong\u003e (front only, back is plain mahogany)\u003c\/li\u003e\n\u003cli\u003eBody Binding: \u003cstrong\u003eMulti-ply, ivory outer\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eSet-in\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNeck Binding: \u003cstrong\u003eIvory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eDouble action, adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e12\" \/ 305mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eParallelogram\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003ePearl White\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eYes\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eTuner Layout: \u003cstrong\u003e3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Holes: \u003cstrong\u003e10mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e43mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (gold cover)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (gold cover)\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 2 Tone, 3-way Toggle Switch\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eNot pre-wired\u003c\/strong\u003e (soldering required)\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eRear-mounted, upper bout\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eGold\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eTune-O-Matic with stopbar tailpiece\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed diecast, 3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eAmber bell knobs\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Cover: \u003cstrong\u003eBlack bell\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4 style=\"margin-top: 24px;\"\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eMahogany guitar body (unfinished) with flamed maple veneer top and multi-ply ivory binding\u003c\/li\u003e\n\u003cli\u003eMahogany set-in neck (unfinished) with bound rosewood fretboard, 22 frets and pearl-white parallelogram inlays\u003c\/li\u003e\n\u003cli\u003e2x gold-covered humbucker pickups (neck and bridge)\u003c\/li\u003e\n\u003cli\u003eGold Tune-O-Matic bridge and stopbar tailpiece with mounting studs\u003c\/li\u003e\n\u003cli\u003e6x gold sealed diecast tuners (3+3) with bushings and screws\u003c\/li\u003e\n\u003cli\u003eWiring kit: 2 volume pots, 2 tone pots, 3-way toggle switch, output jack, hook-up wire\u003c\/li\u003e\n\u003cli\u003eBone nut\u003c\/li\u003e\n\u003cli\u003e4x amber bell knobs\u003c\/li\u003e\n\u003cli\u003eBlack bell truss rod cover\u003c\/li\u003e\n\u003cli\u003eBlack rear control cavity cover and round switch cavity cover\u003c\/li\u003e\n\u003cli\u003e2x gold strap buttons\u003c\/li\u003e\n\u003cli\u003eMounting screws\u003c\/li\u003e\n\u003cli\u003eSteel strings\u003c\/li\u003e\n\u003cli\u003eGuitar cable\u003c\/li\u003e\n\u003cli\u003eAllen wrench\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4 style=\"margin-top: 24px;\"\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eThe electronics in this kit are not pre-wired, so you will need to solder. Depending on the finish and build you have in mind, you may also need:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Soldering iron and solder, wire cutters, Phillips screwdriver, Allen wrench set, wood glue and clamps for the set-in neck joint\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Fine sandpaper (320-600 grit for the veneer), grain filler for the mahogany back and sides, masking tape for the binding, dye or stain, clear coat (polyurethane or nitrocellulose lacquer)\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and bridge height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo routing required: all cavities, holes and channels are pre-cut.\u003c\/p\u003e","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":44231510425734,"sku":"HKL1-RMRG-3","price":249.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-hookline-flamed-maple-rosewood-gold-guitar-kit-01.jpg?v=1786277110","url":"https:\/\/guitarkitworld.com\/products\/hookline-flamed-maple-rosewood-gold-guitar-kit","provider":"Guitar Kit World","version":"1.0","type":"link"}
