{"product_id":"exp-basswood-body-ebony-fretboard","title":"Basswood EXP-style body Guitar Kit, Ebony Fretboard","description":"\u003cp\u003eBuild your own Basswood EXP-style Guitar with Ebony Fretboard using our DIY Guitar Kits.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Beginner (4\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the spalted Maple veneer is thin and easy to sand through, so use a light touch at the edges\u003c\/li\u003e\n\u003cli\u003eBlank headstock ships undrilled and unshaped, so you cut the outline and drill the tuner holes yourself\u003c\/li\u003e\n\u003cli\u003eStraightforward wiring with few connections to solder\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eBasswood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop Veneer: \u003cstrong\u003eSpalted Maple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eEbony\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eTrapezoid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eAbalone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eStandard (as in product images)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 1 Tone, 3-Way\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-1-volume-1-tone-3-way-switch\" target=\"_blank\" rel=\"noopener\"\u003eHH, 1 Volume, 1 Tone, 3-Way Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eTune-O-Matic w\/ stopbar\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed, Diecast\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eAngular-style guitar body (unfinished)\u003c\/li\u003e\n\u003cli\u003eGuitar neck with ebony fretboard and abalone block inlays (unfinished)\u003c\/li\u003e\n\u003cli\u003e6x black sealed tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003e2x black-covered humbucker pickups\u003c\/li\u003e\n\u003cli\u003eBlack tune-o-matic style bridge with posts and thumbwheels\u003c\/li\u003e\n\u003cli\u003eBlack stopbar tailpiece with studs\u003c\/li\u003e\n\u003cli\u003eBlack knobs\u003c\/li\u003e\n\u003cli\u003eBlack neck plate with mounting screws\u003c\/li\u003e\n\u003cli\u003eBlack oval rear cavity cover\u003c\/li\u003e\n\u003cli\u003eBlack truss rod cover\u003c\/li\u003e\n\u003cli\u003eJack plate with output jack\u003c\/li\u003e\n\u003cli\u003eWiring harness with potentiometers and 3-way toggle switch\u003c\/li\u003e\n\u003cli\u003eSet of guitar strings\u003c\/li\u003e\n\u003cli\u003eAllen wrench\u003c\/li\u003e\n\u003cli\u003eBlack instrument cable\u003c\/li\u003e\n\u003cli\u003eAssorted mounting screws\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e","brand":"Guitar Kit World Originals","offers":[{"title":"Out of Stock","offer_id":39480380817542,"sku":"EXP-RBEB-1","price":299.99,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/products\/BasswoodEX-stylebodyGuitarKit_1.jpg?v=1677587499","url":"https:\/\/guitarkitworld.com\/products\/exp-basswood-body-ebony-fretboard","provider":"Guitar Kit World","version":"1.0","type":"link"}
