{"product_id":"diamond-inlay-single-cutaway-guitar-kit-black-hardware-mahogany","title":"Diamond Inlay Single-Cutaway Electric Guitar Kit with Black Hardware, Mahogany Body, Ebonized Fretboard, Humbuckers","description":"\u003cp\u003e\u003cstrong\u003eWhite Pearloid diamond inlays sit in a black ebonized fretboard on this single-cutaway kit, and every piece of hardware is black to match.\u003c\/strong\u003e The tuners, bridge, tailpiece, humbucker rings, knobs, jack plate, nut, pickguard and cavity covers all come in black, so the kit already has a consistent dark trim before you choose a finish for the wood.\u003c\/p\u003e\n\u003cp\u003eUnderneath it is a set-neck single-cutaway build: a two-piece mahogany body with no veneer and a single black binding around the top edge, a mahogany neck that glues into a long neck pocket, 22 stainless steel frets, two black humbuckers, and an adjustable bridge with a stopbar tailpiece.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (7\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eThe set-in neck is glued into the body before finishing, and the neck angle and alignment set your intonation\u003c\/li\u003e\n\u003cli\u003eMahogany has open grain that needs filling before the finish coats for a smooth result\u003c\/li\u003e\n\u003cli\u003eThe black body binding should be masked or scraped clean after staining so the edge stays crisp\u003c\/li\u003e\n\u003cli\u003eEvery cavity, pickup route and post hole is pre-cut, and the adjustable bridge makes intonation straightforward\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e (2 pieces, center joint)\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle Black\u003c\/strong\u003e (top edge)\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eSet-in\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Adjustment: \u003cstrong\u003eHeadstock\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle Black\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eEbonized Wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo (2.7 x 0.9 mm \/ 0.106 x 0.036\")\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDiamond\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eWhite\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eClassic Blues, 3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBlack Plastic\u003c\/strong\u003e (pre-installed)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (black, black ring)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (black, black ring)\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 2 Tone, 3-Way Toggle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-2-volume-2-tone-3-way-toggle-switch\" target=\"_blank\" rel=\"noopener\"\u003e2 Volume, 2 Tone, 3-Way Toggle Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eAdjustable Bridge + Stopbar\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed, Diecast\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack top hat\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Cover: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x unfinished two-piece mahogany single-cutaway body with single black binding, routed for two humbuckers\u003c\/li\u003e\n\u003cli\u003e1x mahogany set neck with ebonized fretboard, White Pearloid diamond inlays and pre-installed black nut\u003c\/li\u003e\n\u003cli\u003e6x black sealed tuners with bushings, washers and screws\u003c\/li\u003e\n\u003cli\u003e2x black humbuckers in black mounting rings\u003c\/li\u003e\n\u003cli\u003e1x control harness with four potentiometers and hookup wire\u003c\/li\u003e\n\u003cli\u003e1x three-way toggle switch with a Rhythm\/Treble ring\u003c\/li\u003e\n\u003cli\u003e4x black top hat knobs with nuts and washers\u003c\/li\u003e\n\u003cli\u003e1x black adjustable bridge with 2 posts\u003c\/li\u003e\n\u003cli\u003e1x black stopbar tailpiece with 2 studs\u003c\/li\u003e\n\u003cli\u003e1x black jack plate with output jack\u003c\/li\u003e\n\u003cli\u003e1x black pickguard with mounting bracket\u003c\/li\u003e\n\u003cli\u003e1x large black control cavity cover\u003c\/li\u003e\n\u003cli\u003e1x round black switch cavity cover\u003c\/li\u003e\n\u003cli\u003e1x black truss rod cover\u003c\/li\u003e\n\u003cli\u003e2x black strap buttons\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003e1x bag of assorted screws\u003c\/li\u003e\n\u003cli\u003e2x Allen wrenches\u003c\/li\u003e\n\u003cli\u003e1x guitar cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set, wood glue and clamps for the neck joint\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, masking tape or a binding scraper, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/lp-guitar-kits\"\u003esingle-cutaway guitar kits\u003c\/a\u003e, or compare the \u003ca href=\"\/products\/lp-diy-kit-mahogany-body-ebony-fretboard\"\u003emahogany kit with an ebonized fretboard and chrome hardware\u003c\/a\u003e and the \u003ca href=\"\/products\/bound-neck-headstock-single-cutaway-guitar-kit-mahogany-rosewood\"\u003ebound neck and headstock kit with Vinework inlay\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67773581361286,"sku":"LP-RMMB-5453","price":229.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-single-cutaway-diamond-inlay-diy-guitar-kit-complete-lp-rmmb-5453.jpg?v=1793018692","url":"https:\/\/guitarkitworld.com\/products\/diamond-inlay-single-cutaway-guitar-kit-black-hardware-mahogany","provider":"Guitar Kit World","version":"1.0","type":"link"}
