{"product_id":"devil-horn-mahogany-guitar-kit","title":"Devil-Horn Double-Cutaway Electric Guitar Kit, Mahogany Body, Set-In Neck, Rosewood Fretboard, Dual Humbuckers","description":"\u003cp\u003eDevil-Horn guitar kit featuring a mahogany body with a symmetric double-cutaway design, a set-in mahogany neck, and a rosewood fretboard with pearl white trapezoid inlays. Standard 24 3\/4\" scale with 22 frets, two humbuckers, a Tune-O-Matic bridge with stopbar tailpiece, and chrome hardware throughout.\u003c\/p\u003e\n\u003ch3\u003eFull Specifications\u003c\/h3\u003e\n\u003ch5\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eOrientation: \u003cb\u003eRight-handed\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cb\u003e6\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cb\u003e628mm \/ 24 3\/4\"\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cb\u003eFull Size\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eBuild Difficulty: \u003cstrong\u003eIntermediate\u003c\/strong\u003e\n\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eElectronics are supplied as a loose wiring harness, and pickup connections require soldering\u003c\/li\u003e\n\u003cli\u003eThe set-in neck joint is fixed, so string height and intonation are dialled in at the bridge and nut rather than by shimming\u003c\/li\u003e\n\u003cli\u003eMahogany is an open-grain wood that benefits from grain filler before finishing\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cb\u003eMahogany (2-4 piece)\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cb\u003eSolid\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cb\u003eDouble\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eBody Binding: \u003cb\u003eNone\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eBody Top Veneer: \u003cb\u003eNone\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cb\u003eMahogany\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cb\u003eSet-in\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eNeck Binding: \u003cb\u003eNone\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cb\u003eRosewood\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cb\u003e22\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cb\u003eTrapezoid\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cb\u003ePearl White\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cb\u003eWave 3+3\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cb\u003eNone\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cb\u003eBone\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cb\u003eHumbucker\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cb\u003eHumbucker\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cb\u003e2 Volume, 2 Tone, 3-way Toggle Switch\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cb\u003eTune-O-Matic with Stopbar Tailpiece\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eHardware Finish: \u003cb\u003eChrome\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cb\u003eBlack\u003c\/b\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cb\u003eBlack\u003c\/b\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eWhat's in the Kit\u003c\/h3\u003e\n\u003cul\u003e\n\u003cli\u003eMahogany guitar body (unfinished)\u003c\/li\u003e\n\u003cli\u003eMahogany neck with rosewood fretboard (unfinished)\u003c\/li\u003e\n\u003cli\u003e2x humbucker pickups\u003c\/li\u003e\n\u003cli\u003eWiring harness (2 volume pots, 2 tone pots, 3-way toggle switch)\u003c\/li\u003e\n\u003cli\u003eChrome Tune-O-Matic bridge and stopbar tailpiece\u003c\/li\u003e\n\u003cli\u003e6x sealed tuning machines\u003c\/li\u003e\n\u003cli\u003eBone nut\u003c\/li\u003e\n\u003cli\u003eBlack pickguard and cavity covers\u003c\/li\u003e\n\u003cli\u003eMounting screws\u003c\/li\u003e\n\u003cli\u003eStrings\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch3\u003eWhat You'll Need\u003c\/h3\u003e\n\u003cp\u003eDepending on the finish and build you have in mind, you may need:\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eFor assembly: Phillips screwdriver, Allen wrench set, soldering iron and solder for the pickup and harness connections\u003c\/li\u003e\n\u003cli\u003eFor finishing: Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat (polyurethane or nitrocellulose lacquer)\u003c\/li\u003e\n\u003cli\u003eFor setup: String winder, tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":35009837203590,"sku":"DVH1-RMRC-1","price":179.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-devil-horn-double-cutaway-guitar-kit-mahogany-rosewood-dvh1rmrc1-01.jpg?v=1785484729","url":"https:\/\/guitarkitworld.com\/products\/devil-horn-mahogany-guitar-kit","provider":"Guitar Kit World","version":"1.0","type":"link"}
