{"product_id":"bound-neck-headstock-single-cutaway-guitar-kit-mahogany-rosewood","title":"Bound Neck and Headstock Single-Cutaway Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Humbuckers, Vinework Inlay","description":"\u003cp\u003e\u003cstrong\u003eIvory binding runs along both fretboard edges, around the headstock face and around the top and back of the body on this single-cutaway kit, so the trim is already in place before you finish the wood.\u003c\/strong\u003e An Abalone Pearloid Vinework inlay climbs the full length of the bound rosewood fretboard: one continuous inlay from the first fret to the upper frets, factory-installed in the board.\u003c\/p\u003e\n\u003cp\u003eUnderneath the trim it is a set-neck single-cutaway build: a mahogany body with no veneer, a mahogany neck that glues into a long neck pocket, 22 stainless steel frets, two chrome-covered humbuckers in ivory rings, an adjustable bridge with a stopbar tailpiece, and an ivory pickguard and cavity covers to match the binding.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (7\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eThe set-in neck is glued into the body before finishing, and the neck angle and alignment set your intonation\u003c\/li\u003e\n\u003cli\u003eMahogany has open grain that needs filling before the finish coats for a smooth result\u003c\/li\u003e\n\u003cli\u003eBody, neck and headstock binding should be masked or scraped clean after staining so the ivory edge stays crisp\u003c\/li\u003e\n\u003cli\u003eEvery cavity, pickup route and post hole is pre-cut, and the adjustable bridge makes intonation straightforward\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e (multi-piece)\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eMulti-ply Ivory\u003c\/strong\u003e (top and back edges)\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eSet-in\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e (adjusted at the headstock)\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle Ivory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eVinework\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eAbalone Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eClassic Blues, 3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eMulti-ply Ivory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eIvory Plastic\u003c\/strong\u003e (pre-installed)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (chrome cover, ivory ring)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (chrome cover, ivory ring)\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 2 Tone, 3-Way Toggle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-2-volume-2-tone-3-way-toggle-switch\" target=\"_blank\" rel=\"noopener\"\u003e2 Volume, 2 Tone, 3-Way Toggle Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eAdjustable Bridge + Stopbar\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed, Diecast\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eIvory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eChrome dome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eIvory\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Cover: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x unfinished mahogany single-cutaway body with multi-ply ivory binding, routed for two humbuckers\u003c\/li\u003e\n\u003cli\u003e1x mahogany set neck with bound rosewood fretboard, Vinework inlay, bound headstock and pre-installed nut\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings, washers and screws\u003c\/li\u003e\n\u003cli\u003e2x chrome-covered humbuckers in ivory mounting rings\u003c\/li\u003e\n\u003cli\u003e1x control harness with four potentiometers and hookup wire\u003c\/li\u003e\n\u003cli\u003e1x three-way toggle switch with cream tip and a Rhythm\/Treble ring\u003c\/li\u003e\n\u003cli\u003e4x chrome dome knobs with nuts and washers\u003c\/li\u003e\n\u003cli\u003e1x chrome adjustable bridge with 2 posts\u003c\/li\u003e\n\u003cli\u003e1x chrome stopbar tailpiece with 2 studs\u003c\/li\u003e\n\u003cli\u003e1x chrome jack plate with output jack\u003c\/li\u003e\n\u003cli\u003e1x ivory pickguard with mounting bracket\u003c\/li\u003e\n\u003cli\u003e1x large ivory control cavity cover\u003c\/li\u003e\n\u003cli\u003e1x round ivory switch cavity cover\u003c\/li\u003e\n\u003cli\u003e1x black truss rod cover\u003c\/li\u003e\n\u003cli\u003e2x strap buttons with felt washers\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003e1x bag of assorted screws\u003c\/li\u003e\n\u003cli\u003e1x Allen wrench\u003c\/li\u003e\n\u003cli\u003e1x guitar cable with one angled plug\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set, wood glue and clamps for the neck joint\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, masking tape or a binding scraper, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/lp-guitar-kits\"\u003esingle-cutaway guitar kits\u003c\/a\u003e, or compare the plain \u003ca href=\"\/products\/standard-mahogany-lp-style-guitar-kit\"\u003emahogany set-neck kit with dot inlays\u003c\/a\u003e and the \u003ca href=\"\/products\/diy-lp-style-guitar-kit-p90-mahogany-ebony\"\u003emahogany kit with P90 pickups\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67654187352198,"sku":"LP-RMRC-5042","price":229.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-single-cutaway-vinework-inlay-diy-guitar-kit-complete-lp-rmrc-5042.jpg?v=1791737998","url":"https:\/\/guitarkitworld.com\/products\/bound-neck-headstock-single-cutaway-guitar-kit-mahogany-rosewood","provider":"Guitar Kit World","version":"1.0","type":"link"}
