{"product_id":"bolt-on-single-cutaway-guitar-kit-pre-wired-mahogany","title":"Bolt-On Neck Single-Cutaway Electric Guitar Kit with Pre-Wired Electronics, Mahogany Body, Bound Ebonized Fretboard, Dual Humbuckers","description":"\u003cp\u003e\u003cstrong\u003eA single-cutaway kit with a bolt-on neck and a bound fretboard.\u003c\/strong\u003e The mahogany neck fastens to the body with four screws through a chrome neck plate, so there is no neck joint to glue or clamp. The ebonized fretboard comes with single white binding fitted along both edges at the factory.\u003c\/p\u003e\n\u003cp\u003eThe electronics arrive pre-wired: two volume pots, two tone pots, the 3-way toggle switch and the output jack are joined on one harness with plug-in connectors, so the wiring goes together without soldering. Around that: a solid mahogany body with no top veneer, white pearloid trapezoid inlays, two chrome-covered humbuckers, an adjustable chrome bridge with a separate stop bar tailpiece, and six chrome sealed tuners.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Beginner (1\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBolt-on neck attaches with four screws and a neck plate, so there is no gluing or clamping\u003c\/li\u003e\n\u003cli\u003ePre-wired harness with plug-in connectors means no soldering anywhere in the build\u003c\/li\u003e\n\u003cli\u003eThe adjustable bridge still needs its four posts seated and the intonation set during setup\u003c\/li\u003e\n\u003cli\u003eMahogany is open-grained, so plan a grain filler step before a gloss finish\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone\u003c\/strong\u003e (plain wood, no veneer)\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e (4 screws and a chrome neck plate)\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e (adjusted at the headstock)\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eEbonized Wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e12\" \/ 305 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eTrapezoid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eSingle White\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eClassic Blues, 3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eIvory Plastic\u003c\/strong\u003e (pre-installed)\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e42 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (chrome cover)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (chrome cover)\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 2 Tone, 3-Way Toggle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003ePre-wired\u003c\/strong\u003e (plug-and-play)\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eAdjustable Bridge\u003c\/strong\u003e (6 adjustable saddles, 2 posts)\u003c\/li\u003e\n\u003cli\u003eTailpiece: \u003cstrong\u003eStop Bar\u003c\/strong\u003e (2 studs)\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack Speed Knobs\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e (control cavity and switch cavity)\u003c\/li\u003e\n\u003cli\u003eTruss Rod Cover: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eUnfinished single-cutaway mahogany body, routed for two humbuckers, with a bolt-on neck pocket, four control holes, a toggle switch hole, a side jack hole and rear control and switch cavities\u003c\/li\u003e\n\u003cli\u003eUnfinished mahogany neck with a bound ebonized fretboard, white pearloid trapezoid inlays, a pre-installed nut and a drilled headstock\u003c\/li\u003e\n\u003cli\u003e1x chrome neck plate with 4x neck screws\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners with bushings and washers\u003c\/li\u003e\n\u003cli\u003e2x chrome-covered humbuckers in black mounting rings, with screws\u003c\/li\u003e\n\u003cli\u003e1x pre-wired harness with 2 volume pots, 2 tone pots, 3-way toggle switch and plug-in connectors\u003c\/li\u003e\n\u003cli\u003e1x output jack with plug-in connector\u003c\/li\u003e\n\u003cli\u003e1x chrome adjustable bridge with 2 posts and bushings\u003c\/li\u003e\n\u003cli\u003e1x chrome stop bar tailpiece with 2 studs and bushings\u003c\/li\u003e\n\u003cli\u003e4x black speed knobs\u003c\/li\u003e\n\u003cli\u003e1x black toggle switch washer with rhythm and treble lettering\u003c\/li\u003e\n\u003cli\u003e1x black pickguard\u003c\/li\u003e\n\u003cli\u003e1x black rear control cavity cover and 1x black round switch cavity cover\u003c\/li\u003e\n\u003cli\u003e1x black bell-shaped truss rod cover with screws\u003c\/li\u003e\n\u003cli\u003e2x chrome strap buttons with felt washers and screws\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003eAssorted chrome nuts, washers and mounting screws\u003c\/li\u003e\n\u003cli\u003e2x Allen wrenches\u003c\/li\u003e\n\u003cli\u003e1x guitar cable with one angled plug\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eThe wiring is pre-wired, so no soldering is needed. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for the truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/lp-guitar-kits\"\u003esingle-cutaway guitar kits\u003c\/a\u003e, or compare the \u003ca href=\"\/products\/mahogany-lp-style-guitar-kit-maple-fretboard-pre-wired\"\u003epre-wired single-cutaway kit with a maple fretboard\u003c\/a\u003e and the \u003ca href=\"\/products\/lp-diy-kit-mahogany-body-ebony-fretboard\"\u003eset-neck mahogany kit with an ebonized fretboard\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67654195871878,"sku":"LP-RMEC-5891","price":219.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-bolt-on-single-cutaway-guitar-kit-complete-kit-lp-rmec-5891.jpg?v=1791737998","url":"https:\/\/guitarkitworld.com\/products\/bolt-on-single-cutaway-guitar-kit-pre-wired-mahogany","provider":"Guitar Kit World","version":"1.0","type":"link"}
