{"product_id":"bolt-on-maple-neck-single-cutaway-guitar-kit-black-hardware-mahogany-rosewood","title":"Bolt-On Maple Neck Single-Cutaway Electric Guitar Kit with Black Hardware, Mahogany Body, Rosewood Fretboard, Humbuckers","description":"\u003cp\u003e\u003cstrong\u003eA bolt-on maple neck with a rosewood fretboard sits on a mahogany single-cutaway body in this kit, and every piece of hardware is black.\u003c\/strong\u003e The neck fastens to the body with four screws and a black neck plate, so you can fit it, check the alignment and take it off again before any glue or finish is involved. The tuners, bridge, tailpiece, humbuckers, knobs, pickguard and cavity covers all come in black.\u003c\/p\u003e\n\u003cp\u003eThe fretboard carries White Pearloid trapezoid inlays and a pre-installed bone nut, 44.5 mm wide. The body is two to three pieces of mahogany with no veneer and no binding, routed for two humbuckers, with an adjustable bridge and a stopbar tailpiece. The factory notes that the real wood is a little darker than it looks in these photos.\u003c\/p\u003e\n\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Beginner (4\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eThe bolt-on neck attaches with four screws, so there is no glue-up and the neck can be removed for finishing\u003c\/li\u003e\n\u003cli\u003eMahogany has open grain that needs filling before the finish coats for a smooth result\u003c\/li\u003e\n\u003cli\u003eEvery cavity, pickup route and post hole is pre-cut, and the adjustable bridge makes intonation straightforward\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e (2-3 pieces)\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eNone (plain wood, no veneer)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Adjustment: \u003cstrong\u003eHeadstock\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e628 mm \/ 24.75\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo (2.7 x 0.9 mm \/ 0.106 x 0.036\")\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eTrapezoid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSide Dots: \u003cstrong\u003eWhite\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eStyled, 3+3\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuner Hole Diameter: \u003cstrong\u003e10 mm (fits modern sealed tuners)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e (pre-installed)\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e44.5 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (black)\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e (black)\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 2 Tone, 3-Way Toggle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring Diagram: \u003cstrong\u003e\u003ca href=\"\/blogs\/wiring-diagrams\/hh-wiring-diagram-2-volume-2-tone-3-way-toggle-switch\" target=\"_blank\" rel=\"noopener\"\u003e2 Volume, 2 Tone, 3-Way Toggle Switch\u003c\/a\u003e\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eAdjustable Bridge + Stopbar\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eSealed, Diecast\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod Cover: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003e1x unfinished mahogany single-cutaway body, routed for two humbuckers and a bolt-on neck\u003c\/li\u003e\n\u003cli\u003e1x bolt-on maple neck with rosewood fretboard, White Pearloid trapezoid inlays and pre-installed bone nut\u003c\/li\u003e\n\u003cli\u003e1x black neck plate with mounting screws\u003c\/li\u003e\n\u003cli\u003e6x black sealed tuners with bushings, washers and screws\u003c\/li\u003e\n\u003cli\u003e2x black humbuckers\u003c\/li\u003e\n\u003cli\u003e1x control harness with four potentiometers and hookup wire\u003c\/li\u003e\n\u003cli\u003e1x three-way toggle switch with a Rhythm\/Treble ring\u003c\/li\u003e\n\u003cli\u003e4x black knobs\u003c\/li\u003e\n\u003cli\u003e1x black adjustable bridge with 2 posts\u003c\/li\u003e\n\u003cli\u003e1x black stopbar tailpiece with 2 studs\u003c\/li\u003e\n\u003cli\u003e1x black jack plate with output jack\u003c\/li\u003e\n\u003cli\u003e1x black pickguard with mounting bracket\u003c\/li\u003e\n\u003cli\u003e1x large black control cavity cover\u003c\/li\u003e\n\u003cli\u003e1x round black switch cavity cover\u003c\/li\u003e\n\u003cli\u003e1x black truss rod cover\u003c\/li\u003e\n\u003cli\u003e2x black strap buttons\u003c\/li\u003e\n\u003cli\u003e1x set of strings\u003c\/li\u003e\n\u003cli\u003e1x bag of assorted screws\u003c\/li\u003e\n\u003cli\u003e1x Allen wrench\u003c\/li\u003e\n\u003cli\u003e1x guitar cable\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e\n\u003cp\u003eBrowse the full range of \u003ca href=\"\/collections\/lp-guitar-kits\"\u003esingle-cutaway guitar kits\u003c\/a\u003e, or compare the \u003ca href=\"\/products\/diamond-inlay-single-cutaway-guitar-kit-black-hardware-mahogany\"\u003ediamond inlay kit with black hardware and a set neck\u003c\/a\u003e and the \u003ca href=\"\/products\/bolt-on-single-cutaway-guitar-kit-pre-wired-mahogany\"\u003ebolt-on kit with pre-wired electronics\u003c\/a\u003e.\u003c\/p\u003e\n","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":67788976291974,"sku":"LP-RMMB-5720","price":229.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-trapezoid-inlay-single-cutaway-diy-guitar-kit-complete-lp-rmmb-5720.jpg?v=1795426684","url":"https:\/\/guitarkitworld.com\/products\/bolt-on-maple-neck-single-cutaway-guitar-kit-black-hardware-mahogany-rosewood","provider":"Guitar Kit World","version":"1.0","type":"link"}
