{"product_id":"alder-st-style-guitar-kit-quilt-maple","title":"Double-Cutaway Contoured Electric Guitar Kit, Alder Body, Quilted Maple Veneer, Dual Humbuckers","description":"\u003cp\u003eBuild a double-cutaway electric guitar with an alder body, a quilted maple top and two humbucking pickups. The body arrives with every cavity and hole already cut. Its flat top has a forearm contour on the edge and a belly cut on the back, so it sits comfortably against you while you play.\u003c\/p\u003e\n\u003cp\u003eThe maple neck has a dark skunk stripe down the back, an engineered rosewood fretboard, 22 stainless steel frets and a bone nut. Stainless steel frets stay smooth and wear far more slowly than standard nickel-silver frets. The headstock comes blank, with all six tuner holes already drilled in a single row, so you can keep its plain outline or cut your own shape. The neck attaches with four screws, with no gluing or clamping.\u003c\/p\u003e\n\u003cp\u003eThe black pearl pickguard comes with both pickups, one volume knob, two tone knobs and the 5-way switch already mounted. You solder the connections yourself, which is how you learn what each control does. A six-saddle tremolo bridge and chrome sealed tuners complete the hardware. The body and neck come unfinished, ready for whatever color you choose.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e6\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBuild Difficulty: Intermediate (6\/10)\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBolt-on neck joint bolts straight on, so there is no gluing or clamping to get right, but the quilted Maple veneer is thin and easy to sand through, so use a light touch at the edges\u003c\/li\u003e\n\u003cli\u003eThe headstock is a blank 6-in-line with its tuner holes already drilled, so you can finish it as it is or cut your own outline\u003c\/li\u003e\n\u003cli\u003eTremolo bridge requires careful setup for tuning stability\u003c\/li\u003e\n\u003c\/ul\u003e\n\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eAlder (2-3 pc)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eDouble\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eContours: \u003cstrong\u003eFlat top with forearm contour and belly cut\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eQuilted maple veneer (thin sheet, about 0.5 mm)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMaple with skunk stripe\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e648mm \/ 25.5″\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood (Engineered)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eDot\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Plastic (ABS)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eBlank 6-in-line (tuner holes drilled)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eMiddle Pickup: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eHumbucker\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e1 Volume, 2 Tone, 5-Way Selector\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eTop jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eTremolo\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eChrome Sealed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eBlack Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eChrome\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat's in the Box\u003c\/h4\u003e\n\u003cul\u003e\n\u003cli\u003eGuitar body with figured maple top (unfinished), pickguard already fitted\u003c\/li\u003e\n\u003cli\u003eGuitar neck with engineered rosewood fretboard and white dot inlays\u003c\/li\u003e\n\u003cli\u003eBlack pearl pickguard fitted with two black open-coil humbuckers, three black skirted knobs and a blade switch\u003c\/li\u003e\n\u003cli\u003e6x chrome sealed tuners\u003c\/li\u003e\n\u003cli\u003e6x chrome tuner bushings\u003c\/li\u003e\n\u003cli\u003e6x chrome washers with mounting screws\u003c\/li\u003e\n\u003cli\u003eSet of guitar strings\u003c\/li\u003e\n\u003cli\u003eBlack tremolo cavity cover plate with six string slots\u003c\/li\u003e\n\u003cli\u003eChrome neck plate\u003c\/li\u003e\n\u003cli\u003eBlack neck plate gasket\u003c\/li\u003e\n\u003cli\u003e4x neck mounting screws\u003c\/li\u003e\n\u003cli\u003eChrome six-saddle tremolo bridge\u003c\/li\u003e\n\u003cli\u003e3x tremolo springs\u003c\/li\u003e\n\u003cli\u003eChrome spring claw with two mounting screws\u003c\/li\u003e\n\u003cli\u003eChrome tremolo arm\u003c\/li\u003e\n\u003cli\u003e2x Allen wrenches\u003c\/li\u003e\n\u003cli\u003eChrome boat-shaped output jack cup with output jack fitted\u003c\/li\u003e\n\u003cli\u003eAssorted mounting screws\u003c\/li\u003e\n\u003cli\u003eBlack instrument cable with straight and right-angle plugs\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":31669705343110,"sku":"ST-RAOC-1","price":229.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/products\/alder-st-style-guitar-kit-with-quilted-maple-veneer-maple-skunk-stripe-neck-754365.png?v=1684849011","url":"https:\/\/guitarkitworld.com\/products\/alder-st-style-guitar-kit-quilt-maple","provider":"Guitar Kit World","version":"1.0","type":"link"}
