{"product_id":"34-inch-5-string-exp-bass-style-guitar-kit-mahogany-body-spalted-maple-veneer","title":"Spalted Maple Veneer 34-Inch 5-String EXP Bass Style Guitar Kit, Mahogany Body","description":"\u003cp\u003e\u003cstrong\u003eA spalted maple veneer top on a mahogany body: this is the spalted version of our 34-inch 5-string EXP style bass kit, the same kit as the \u003ca href=\"\/products\/bass-exp-style-guitar-kit\"\u003eflamed maple version\u003c\/a\u003e except for the top.\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003eBuild your own professional grade 34 inch 5 string EXP style bass guitar with this mahogany body DIY kit, topped with a spalted maple veneer. Designed for players who want aggressive styling and balanced low end performance, this kit includes a solid mahogany body, a bolt on mahogany neck, and a Rosewood fretboard with white pearloid trapezoid inlays. The 22 fret, 34 inch scale setup delivers familiar feel and extended range tuning stability ideal for rock, metal, and modern bass tones.\u003c\/p\u003e\n\u003ch4\u003eFull Specifications\u003c\/h4\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eGeneral\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eDexterity: \u003cstrong\u003eRight-Handed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Strings: \u003cstrong\u003e5\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eSize: \u003cstrong\u003eFull Size\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eBody\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany (2-3 pcs)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eConstruction: \u003cstrong\u003eSolid wood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eType: \u003cstrong\u003eSolid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCutaway: \u003cstrong\u003eSingle\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTop: \u003cstrong\u003eSpalted maple veneer (thin sheet, about 0.5 mm)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eNeck\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eMahogany\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eJoint: \u003cstrong\u003eBolt-on\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eProfile: \u003cstrong\u003eC-shaped\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTruss Rod: \u003cstrong\u003eTwo-Way, Adjustable\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eScale Length: \u003cstrong\u003e864 mm \/ 34\"\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eFretboard\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eMaterial: \u003cstrong\u003eRosewood\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eRadius: \u003cstrong\u003e14\" \/ 356 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNumber of Frets: \u003cstrong\u003e22\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Wire: \u003cstrong\u003eStainless Steel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFret Size: \u003cstrong\u003eMedium Jumbo (2.7 x 0.9 mm \/ 0.106 x 0.036\")\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Shape: \u003cstrong\u003eTrapezoid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eInlay Material: \u003cstrong\u003eWhite Pearloid\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHeadstock\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eShape: \u003cstrong\u003eEdge\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBinding: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut: \u003cstrong\u003eBlack Plastic (ABS)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eNut Width: \u003cstrong\u003e45 mm\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eElectronics\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eNeck Pickup: \u003cstrong\u003eP90\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eBridge Pickup: \u003cstrong\u003eP90\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eControls: \u003cstrong\u003e2 Volume, 1 Tone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eWiring: \u003cstrong\u003eDIY (soldering required)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eOutput Jack: \u003cstrong\u003eSide jack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch5 style=\"margin-top: 14px; margin-bottom: 6px; color: #555;\"\u003eHardware\u003c\/h5\u003e\n\u003cul\u003e\n\u003cli\u003eBridge: \u003cstrong\u003eFixed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eTuners: \u003cstrong\u003eClosed\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003ePickguard: \u003cstrong\u003eNone\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eKnobs: \u003cstrong\u003eStandard (as in product images)\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eCavity Covers: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eStrings: \u003cstrong\u003eSteel\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003cli\u003eFinish: \u003cstrong\u003eBlack\u003c\/strong\u003e\n\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003ch4\u003eWhat You'll Need\u003c\/h4\u003e\n\u003cp\u003eYou will need to solder the electronics. Depending on the finish you choose, the tools below cover a standard build.\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor assembly:\u003c\/strong\u003e Phillips screwdriver, Allen wrench set\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor wiring:\u003c\/strong\u003e Soldering iron, solder, wire cutters\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor finishing:\u003c\/strong\u003e Sandpaper (220-600 grit), wood grain filler, primer, paint or stain, clear coat\u003c\/li\u003e\n\u003cli\u003e\n\u003cstrong\u003eFor setup:\u003c\/strong\u003e String winder, guitar tuner, Allen wrench for truss rod and saddle height adjustment\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003eNo woodworking or routing required - all cavities, holes, and channels are pre-cut.\u003c\/p\u003e","brand":"Guitar Kit World Originals","offers":[{"title":"Free Shipping – International Warehouse","offer_id":44191266013318,"sku":"EXPB-RMOB-2","price":274.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0065\/9374\/0911\/files\/guitarkitworld-spalted-maple-veneer-5-string-bass-guitar-kit-complete-kit-expb-rmob-2.jpg?v=1791972080","url":"https:\/\/guitarkitworld.com\/products\/34-inch-5-string-exp-bass-style-guitar-kit-mahogany-body-spalted-maple-veneer","provider":"Guitar Kit World","version":"1.0","type":"link"}
