Wood Grain Filler for Guitar Bodies
All hardwoods are fairly open grained, some more than others. To achieve a smooth glossy finish we require an even surface to work with and when using an open grain timber such as Mahogany this can be difficult. To achieve this the open pores of the timber should be filled using wood grain filler. It's not a difficult job but there are a few basic steps to keep in mind which we will outline below.
What is Wood Grain Filler?
Recommended: Guitar Finishing 101: The Highlighted Grain & Stain Finish
It comes down to what you prefer to work with but in my own experience, it's not a bad idea to stick with water based grain filler as it's less messy and dries quickly. Purists may disagree but in my opinion, water-based products have come such a long way in recent times that it really makes little difference choosing water based or oil based fillers, paints and stains for the most part anymore. You can generally purchase grain filler in clear or tinted variations.
You can also add a water-based pigment to achieve the color you prefer. It's best not to overdo things though as you can effect the drying time if you use too much. If in doubt use no more than 10%-15% pigment.
Grain Filler Application
Once you have worked enough grain filler into the timber you can start to scrape away any excess. Be sure to scrape the filler away quickly as water-based grain filler dries very quickly once not being worked with the rag. Wood grain filler also tends to dry quite hard, meaning you are going to raise a sweat if sanding too much excess of by hand.
