How to wire a 3 single coil, 1 vol, 1 tone, 5-way selector guitar
In this article, we will walk you through the process of wiring a guitar with 3 single coil pickups, 1 volume, 1 tone, and 5 way switch. Wiring a guitar is not that difficult if you know what to do and have the right resources to refer to. This guitar wiring diagram is common in most Stratocasters and I have included a wiring diagram of a stratocaster below.
Source: https://guitarelectronics.com/guitar-wiring-resources/
Do you want to learn more on how guitar electronics works? Check out this article explaining how guitars work
Take The Quiz
Fixing a Loose Neck Pocket on DIY Guitar Kits: Causes, Diagnosis & Reliable Repairs
A loose-fitting neck pocket is one of the most common setup issues in DIY guitar kits —especially...
Jason’s Epoxy DIY Guitar Kit Build
At Guitar Kit World, we love seeing how our builders take a standard DIY electric guitar kit and ...
Baritone Guitar Kits
If you have more than a passing interest in guitars, chances are you are aware of baritone guitar...
