Best Guitar Bridge Options for Kit Guitars
In the following article, we're going to take a closer look at some of the best guitar bridge options available for kit guitars. This isn't an exhaustive list of guitar bridges, however, the bridges listed below are what you will find on 99% of all kit guitars.
Also Read: DIY Guitar Kit Bridges and Tailpieces
Your bridge is a super important component of your kit guitar and allows you to adjust your action, set your intonation, and in the case of a tremolo bridge will allow you to integrate a whammy bar into your playing. It's important to have a grasp on the capabilities of your bridge and also any potential limitations.
Fixed Guitar Bridges
The Ashtray Bridge
The 3 saddle configuration holds two strings per saddle, meaning two strings are adjusted at a time. Many purists prefer this setup, due to the increased size of the saddles compared to a typical 6 saddle configuration. many consider the larger saddles capable of providing better tone and sustain.
Alternatively, the 6 saddle configuration allows for greater control over intonation as each individual string is able to be adjusted.
Recommended: TE style DIY Guitar Kits
Tune-o-Matic Bridge
Gibson style kit guitars utilize a fixed bridge known as the 'Tune o Matic' bridge which comes equipped with a stud mounted stop tailpiece. These require a little more work to install compared to the Ashtray bridge, but I would still consider this style of bridge something anyone could install without too much difficulty.
Tremolo Bridges
The ST 6 saddle bridge
This type of bridge features either 6 (vintage) or two (modern) front mount screws to hold the bridge in place. The bridge is then attached to three coil springs that run through the body of the guitar allowing sufficient tension for playing using the tremolo bar.
Floyd Rose Floating Tremolo
The Floyd Rose locking tremolo as the name suggests is also a tremolo bridge however it has been designed to allow more extreme variations in pitch and control over the tremolo while also offering greater tuning stability thanks to the double-locking design. The double-locking design allows for the floating bridge and nut to lock down on the strings.
The Ashtray Bridge
Tune-o-Matic Bridge
