Headless Guitar Kit Assembly Manual
Step-by-step instructions on how to build your own DIY Headless guitar. Get started by reading the following tutorial even if you're a first-time builder.
There’s nothing more satisfying than playing a unique headless guitar you have put together yourself.
So let’s get started!
Project Tools and Consumables
Before we get started check the list below and ensure you have the necessary tools and consumables required to complete the project
Tools
- Steel ruler (at least 40 cm)
- Hard sanding block
- Soldering iron
Consumables
- Disposable gloves
- Small paintbrush
- Painters masking tape
- 0000 fine grade steel wool
Parts List
Below are the parts you will find included in your packaging to complete an HL guitar kit.
- Prepped HL body
- Completed neck
- Neck plate, neck plate cushion and screws
- 2 x Strap buttons
- HL Tremolo Bridge
- Whammy bar or Vibrato bar
- Electronics (1x Volume knob, 1x Tone knob, and a 5-Way Selector switch)
- 1 humbucker pickup with pickup ring
- 2 single coil pickups
- Input jack
- Hex wrench (for adjusting truss rod)
- Set of strings
- Assorted screws and washers
Safety Precautions
Protective eyewear
Disposable gloves
Masks
A well ventilated work area
Making your Guitar Kit play & Sound Great
- Preparation and finishing
- Hardware Installation
Fitting strap buttons, bridge, and pickups.
- Connecting the electronics
1 Humbucker/2 Single Coils/5-Way Switch/1 Volume/1 Tone
- Final Setup
